48" Crash Tender
Mark,
A good motor, but really for aircraft,i.e. does not have watercooling...look at watercooled brushless with the same company, the ESC is the same as mine, I use a large standard rudder purchased from cornwall models and a 50mm two blade prop NOT an X speed. I had a three blade 60mm brass prop on originally, that worked fine until I lost it in the lake, so you have a bit of a choice
