Best way to hold small parts?
Started by bustedknuckles
11 replies 14 likes Last activity: 7 years ago
I have added heat shrink to some tweezers and that is a big improvement. I have also ordered a set of reverse pliers. ( you can't have too many tools!)
The steady hands are something I can't do much about.
Thanks again for all the replies!
Liked by Martin555
The clues are; broad tips on the tweezers, so they can't flip over each other and spin the part out, and a steady hand.
Liked by Martin555
Great for grabbing dropped things inside your boat; grasping battery, and other wires that are hiding under the deck.
I find that unlocking them creates more problems than it solves,as as it always moves the part
Liked by Martin555
I use Forceps of various sizes, some straight and others curved.
Liked by Martin555
"At least with cross over tweezers it is a more constant pressure."
The trick being that YOU don't have to apply that pressure, the tweezer does😉
Liked by Martin555
Thank for the replies. I have appropriate heat shrink, so I can start from there. I'll try it asap and report back....
Liked by Martin555
In the past i have even used a small piece of sticky back draft excluder.
"My solution is to use a couple of pieces of rubber insulation from electrical wire or some heat shrink tubing."
That works up to a point Martin.
It can be very hard to release the part without wiggling it sometimes.
Depending on how much the part stretches the rubber.
I tried it with silicon sleeving (look in the Missusseses iron😊) works a bit better as the silicon gives more on release. Heat shrink is very stiff☹️
I prefer the 'cross over' tweezers (don't forget the Town & Country tires😁) though - instant release👍
Liked by Martin555
Hi BK, (ex Prize fighter by any chance?😉)
Maybe what you need are these, reverse action tweezers-
https://www.amazon.com/Testors-8942T-Reverse-Action-Tweezers/dp/B003ZD1148
As usual, and you can see in the link, there are various versions at various prices!
Liked by Martin555
Hi,
I posted this in the hints and tips section.
Just pop it over the tips of said tools, this will give a little more grip with out damaging the piece and stops it from pinging out.
Hope this helps.
Liked by ianed57 and RNinMunich
I'm looking for suggestions as the the best way to hold small parts. They slip in my tweezers, and my fingers are well, clumsy. I need a way to grip them that won't damage the part, hold them securely, and release easily once the part is placed...
Liked by Joe727 and Martin555
