In need of guidance
Followers (1)
In need of guidance
I'm going to try and find a boat club around here, but with current lockdown restrictions i'm unsure if that'll be all that easy..
I've a few cosmetic bits to finish whilst im waiting on the exhaust / muffler to be done, but I am hoping to take it on our lake beginning of next week..
Daz
In need of guidance
Years ago we used to use a square leather boot lace to start boat motors. You don't wind the cord round the flywheel,- just loop it under the flywheel and holding the boat down firmly (a helper is good for this) using both hands, apply tension to the cord and pull up (to make the flywheel move anti clockwise (from the front of the motor), - slacken the tension, bring cord back and repeat ( sort of zip the cord back and forth quickly, - tension pull,-relax pull back etc).
You will need to prime the motor by hand (finger over carb while turning anti clockwise by hand till you see fuel coming down the line and into the carb . If motor locks, it's flooded,- remove glow plug, spin motor with cord or starter to get rid of excess fuel, replace plug (do not overtighten plugs,- firm is fine) and re-try. Experience will get you sorted. As martin suggested, a good idea would be to go to your local boat racing club for direct advice.
Make sure you start on very low throttle to avoid over revving the motor and get it in the water as quickly as possible to avoid overheating. Hope this gives you a bit more of an idea.
See guy using cord starting in beginning of vid. Pic of green boat is one I built around 1977 and has the same O.S Max .40 as yours. Went quite well and very reliable.
In need of guidance
I have tried looking for the start up method on utube but at the moment i an unable to find anything.
It is like a large "O" ring that goes between two pulleys
One on a starter motor and one in the prop shaft (see quick sketch)
I have seen a nipple or tube brazed to the silencer part of the exhaust system.
As i have mentioned i don't know a lot about this type os system but the best guys to help you with this would be the guys that run the fast speed boats.
In need of guidance
I'll have a look through the instructions that i was given for the 30. Im just wondering as the exhaust system is a custom built copper. Unsure where i would put the breather tube on to the exhaust... i'll do some more reading..
Thankyou everyone for all the assistance, it's greatly appreciated.
Cheers Daz
In need of guidance
The piping that goes back to the fuel tank from the exhaust is to pressurise the fuel system.
As for a Firewall i don't think it should get that hot to need one, but there is no harm i fitting one just for piece of mind.
I have seen a system for starting that uses a separate battery powered motor and a belt that fits around the shaft pulley.
In need of guidance
One question. Im thinking of putting a fireboard between engine and fuel tank. There wasnt one when i was given it but im unsure as to the amount of heat that it will produce, the exhaust is something that the old bloke created, im unsure what was meant by a pipe going back into fuel tank? Ive attached a couple of pictures..
Lastly im a director for a social enterprise and we have a boating lake and fishing lake, im looking to create an rc club, once ive set it up would it be ok to promote the club on here?
Many thanks Daz
In need of guidance
Hi Daz, here's a manual from a Max .30 I have, (same info as the .40) You can buy the fuel from most model shops ready made . Don't use high nitro fuels as these motors should have no more than 5% max for contest use as they are not built for too much nitro. They are a ringed motor (Dykes ring) not ABS and you will cook it on too much nitro.
If you can find quality first pressing caster oil for model use, that's the best (although messy) as it lubricates well at high temps. Nitro use causes rust in the engine (although the .40 Max only has bushes not bearings so is not affected as much) and requires using an after run oil to prevent this, - (caster just goes gooey with long time storage.)
Don't think you will find any caster fuel these days though as it is mostly synthetic oils now. Fuel should be as close to the proportions shown when buying from the model shop, (minimum nitro or none, as these don't need nitro)
The methanol and oil are pre-mixed (do not use petrol and 2 stroke oil,- it wont run). You'll need a glow lead with a 1.5-2v battery for starting (depending on plug specs) Use an O.S No 7 plug (watch the lengths of other plugs re piston clearance, temp etc)
Hope this helps.
In need of guidance
Contact model car web site as i think these engine are used in them.
I have spoken to my son who was into fuel driven engines
1 the fuel you buy has the lubricant mixed in eg nitro 16, nitro 20, etc. the higher the number the more performance. However too high will burn out the engine.
2 He assumes the starting is by pull cord.
3 He also asked if the engine is water cooled, the engine needs cooling, cars just use airflow.
4 The current engine use a pipe from the exhaust to the fuel tank as part of the fuel supply. if not the engine may use petrol oil mix like two stroke mixture.
5 in a down side these engines can be tempermental . Patience required.
If you wish more information please post some photos of the engine setup.
He says a good model shop should give you good advice.
In need of guidance
I have very limited experience with these types of motors but i think the oil is already mixed in the fuel.
Hopefully other members will be able to help you more.
In need of guidance
I have been given an old boat, it has an OS MAX 40rc engine. I've rebuilt the boat for an old bloke who used to own it.
I know nothing about mechanical engines anyone that can give me a bit of mentorship with this engine i'd greatly appreciate.
The glow plug works fine and the nitro fuel is 15% ( on the advice of the local model shop).
From reading (lots of) i have a basic understanding, but i would presume that i have to put oil in it somewhere so it doesnt seize up, i really dont have a clue and dont want to bugger it up having spent months rebuilding the boat, reciever, controller and wooden hull. The boat is circa 1970. I'd really like to get it working for him; so he can see it before he passes away( he's 84)..
Thanks in advance
Daz
Liked by
Loading…
