Plans
Started by gogetemfloyd
8 replies 3 likes Last activity: 6 years ago
Plans
Aw shucks Floyd 🤔
But I'm sure I've seen a plan / kit for a KM Kriegsfischkutter somewhere.
Memory not that what it once was 🤔
I'll dig around and get back to you if I find summat!
Liked by Ianh
Plans
Cheers for the info but it apparently has no hull plans. Looks like i'm a day late and a dollar short for this project. Thanks ,floyd
Plans
Hi roy, i was hoping to convert the kit to a 1/35 kriegsfischkutter, i thought the hull would prove to be a problem. Thanks anyhow. Floyd
Plans
Hi, the Elke 408 is a Graupner kit now out of production, and the hull is ABS plastic, so no hull drawings to build from.
Does it have to be this boat? The Billings Mary Ann is a slightly smaller but similar fishing boat. The kit is still available.
Alternatively if you go on-line to Sarik model boat plans you will find a lot of fishing boats from several eras to choose from.
Good luck
Plans
I have built a couple of these boats many years ago, the kit uses a plastic hull so I don't think the plans have any hull lines or formers. I will try and find them and check if you wish.
Liked by Rookysailor
Plans
Hi all, i'm looking for the best place to get plans to build the graupner ELKE 408. Cheers.
