Battery Charging
Hi Bikerjohn, I know that the high capacity AA cells look a good idea, there are some buts however. If you are using old 40 Mhtz or even 27 (like wot I duz) you will find that the new hi cap cells are a little fatter than the 600 and 800 mAh cells we used to use.
You may not be able to get the back cover on the Tx.
Also consider how long you wish to run the radio for. I am happy with a long afternoon say 3-4 hours. This means that you may be overlooking cheaper 2000mAh cells that will do the job just as well.
I have some old 40 MHtz Tx's and have found another solution. I favour the 3 channel Hitec 40Mhtz FM Tx's as they are 2 proportional channels and a 3rd. ch with a set position that I use for sail trimming.
Component Shop made me a couple of 10 cell 12 volt AAA batttery packs. These are 950 mAh capacity and last 4.5 hours. I asked for a normal servo end connection and soldered a female end on a wire into the back of the Tx. It can be charged en situ.
I do not need to remove any cell contacts as the pack fits in nicely and best of all it is cheaper!
I use an intelligent charger that can handle 10 cells or 12 volts, choose carefully as not all of them can, I think it cost £13.
I am not conversant with 2.4 Ghtz but I understand some run on just 4 cells.
Sorry to muddy the water.
