I think these are the fittings that you may have; https://robart.com/collections/air-systems-components-air-couplers/products/air-line-quick-disconnects
I use these and they are reliable.
Algon, that looks like the male ends I have. Is this the female part? https://www.coleparmer.com/i/cpc-colder-miniature-quick-disconnect-fitting-hosebarb-body-acetal-straight-through-1-8-id-10-pk/0636356
Yup. Look like Robart fittings. I use them on my sub with moderate pressure lines. They work well and have not leaked or failed in 12 years.
Try here:
https://www.coleparmer.com/i/cpc-colder-miniature-quick-disconnect-fitting-hosebarb-insert-acetal-straight-through-1-8-id-10-pk/0636352?PubID=UX&persist=true&ip=no&msclkid=363a20779b821e79b71a418618bc9084&utm_source=bing&utm_medium=cpc&utm_campaign=Shopping_PLA_Main(BSC)&utm_term=4585032209406125&utm_content=Tubing%20and%20Hose
I know its a scary long link but I think this is what you are looking for, Company is called CPC Colder.
Just copy and paste in your browser.
You didn't give dimensions in your post, These have an 1/8" ID. Good Luck!
Thank You!
I looked at Robart's website, and I believe you are correct.
I sent pictures to Robart, to have them verify if they are indeed their fittings.
If so, this will solve one of the last unanswered questions about this boat!
Thank You!
It looks like Robart quick release joint. these are normaly used in model aircraft. Available from Bobs Hobbies. Orlando.
I bought a model cargo ship from the widow of a friend of mine. It needed some TLC, but I have the electronics sorted out, and it is basically water-ready. However, there are several what appear to be quick-detach fittings on the water lines for cooling the motors, and also for the fire monitors. I cannot seem to identify the brand and/or supplier so that I can complete the connections. Does anybody here recognize these, and know where I can buy them?
Thanks for looking!
[{"id":"164315609541","name":"164315609541.jpg","caption":"","url":"https:\/\/model-boats.com\/media\/164315609541\/l","thumbUrl":"https:\/\/model-boats.com\/media\/164315609541\/s","isImage":true,"ext":"jpg"},{"id":"164315611035","name":"164315611035.jpg","caption":"","url":"https:\/\/model-boats.com\/media\/164315611035\/l","thumbUrl":"https:\/\/model-boats.com\/media\/164315611035\/s","isImage":true,"ext":"jpg"},{"id":"164315612560","name":"164315612560.jpg","caption":"","url":"https:\/\/model-boats.com\/media\/164315612560\/l","thumbUrl":"https:\/\/model-boats.com\/media\/164315612560\/s","isImage":true,"ext":"jpg"},{"id":"164315619786","name":"164315619786.jpg","caption":"","url":"https:\/\/model-boats.com\/media\/164315619786\/l","thumbUrl":"https:\/\/model-boats.com\/media\/164315619786\/s","isImage":true,"ext":"jpg"}]
Thanks for looking!
