Β£2.50
Β£4.50
Β£6.50
Valid 12 Months
Β£25
Β£45
Β£65
    Make plank strips look like one piece (no lines)
    7 Posts Β· 4 Followers Β· 0 Photos Β· 5 Likes
    Began 1 year ago by
    Leading Seaman
    Latest Post 1 year ago by
    Commodore
    United States
    pressonreguardless
    Commodore
    πŸ‡ΊπŸ‡Έ United States
    πŸ“ Make plank strips look like one piece (no lines)
    Country: πŸ‡ΊπŸ‡Έ United States
    Online: 17 hours ago
    😊 View Profile
    πŸ’¬ Send PM
    Yes,
    My Typhoon is double planked with the final planking being 1/4 and 1/8th inch wide Mahogany strips. The hull is like glass.
    The 1/8th is for the areas that have more of a curve.
    It is time consuming. For best results each planks edge should be slightly beveled to insure a tight fit. On full sized boats this was called spiling the planks.
    After sanding to achieve a fair hull, it should be coated with a sealer, thin epoxy is my choice. Then coated with a heavier coats after sanding between each to achieve a smooth finish
    Good Luck,
    Trev
    Griss
    Chief Petty Officer 2nd Class
    πŸ‡¬πŸ‡§ United Kingdom
    Online: 3 days ago
    😊 View Profile
    πŸ’¬ Send PM
    πŸ’΅ Gift Membership
    Steam itπŸ‘
    RudyM
    πŸ‡ΏπŸ‡¦ South Africa
    Country: πŸ‡ΏπŸ‡¦ South Africa
    Online: 11 months ago
    😊 View Profile
    πŸ’¬ Send PM
    You can bend it with the grain yes but why not use ABS instead?
    Rudy Maritz ADF - Northern City Model Boat Club
    roboboyo
    Leading Seaman
    Online: 5 months ago
    😊 View Profile
    πŸ’¬ Send PM
    Thanks for all the reply’s guys
    I’m after a smooth finish, like a ro ro passenger ferry.
    Is ply wood bendable to create the contours?
    mturpin013
    Vice Admiral
    41 Views Β· 2 Likes
    Online: 14 hours ago
    😊 View Profile
    πŸ’¬ Send PM
    You don't say if its a planked hull or deck the later being easy just use one sheet of ply, however the hull can also be covered in ply sheet however more care with any joins must be taken.
    You don't say why you want (No lines) real ships have linesπŸ€”
    RudyM
    39 Views Β· 2 Likes
    😊 View Profile
    πŸ’¬ Send PM
    Not sure why you plank it to look solid but yes it would be possible of your planking is thick enough. But you will have to use the clinker method of planking and sand it down. Depending on your hull shape using wider planks will help.
    roboboyo
    Leading Seaman
    39 Views Β· 1 Like
    😊 View Profile
    πŸ’¬ Send PM
    Hi guys, sorry if this a stupid question (I’m a complete novice in modelling) is it possible to hide lines in plank strips so it looks like one solid piece?
