Lock Nuts on Props
Started by Dumaspittman
4 replies 7 likes Last activity: 4 years ago
Lock Nuts on Props
If you use a thread locking compound, I would use Locktite low strength pink, or Vibra-tite thread locker.
LEN1
Liked by Dumaspittman
Lock Nuts on Props
I thought so! It always pays to check.
Thanks.
Lock Nuts on Props
Lock nuts should be OK but loctite would be belt and braces. It is possible to release loctite with a small amount of heat, so its not permanent.
Liked by Colin H and pressonreguardless
Lock Nuts on Props
I have a question that I could use some advise on. If I use lock nuts on props, do I need to also use Locktite? The screws are part of a rather high powered system with 800 motors driving 1.5 inch props with dogs.
Thanks!
Liked by pressonreguardless
