Great idea Martin. Just a thought on my part but if you were to use 3 holding screws instead of 4 you can also easily hold hex shapes and still have the ability to center other shapes.
Superb idea Martin. If you bolt them to a plate, add a small electric motor to one end and a couple of bearings to the cap you have a small lathe.
Peter.👍😊
Peter.👍😊
Hi Guys,
When I was working on mast's, yard's, or anything that required painting I found It a little difficult as things keep slipping of of blocks when working or painting.
So I knocked up a couple of holders.
These can be used horizontally or vertically and rotated as and when required.
Due to the 4 Allen bolts you can grip round or square in fact most shapes, you are only limited to the diameter of the Bottle tops.
Made from scrap blocks of wood.
8 x 5mm Allen bolts.
2 x large Bottle tops.
And 2 x long bolts for the main shafts.
[{"id":"167188403630","name":"167188403630","caption":"","url":"https:\/\/model-boats.com\/media\/167188403630\/l","thumbUrl":"https:\/\/model-boats.com\/media\/167188403630\/s","isImage":false,"ext":"file"},{"id":"167188403696","name":"167188403696","caption":"","url":"https:\/\/model-boats.com\/media\/167188403696\/l","thumbUrl":"https:\/\/model-boats.com\/media\/167188403696\/s","isImage":false,"ext":"file"},{"id":"167188403819","name":"167188403819","caption":"","url":"https:\/\/model-boats.com\/media\/167188403819\/l","thumbUrl":"https:\/\/model-boats.com\/media\/167188403819\/s","isImage":false,"ext":"file"},{"id":"167188403870","name":"167188403870","caption":"","url":"https:\/\/model-boats.com\/media\/167188403870\/l","thumbUrl":"https:\/\/model-boats.com\/media\/167188403870\/s","isImage":false,"ext":"file"}]
