    Vosper Crash Tender Motor
    3 Posts ยท 3 Followers ยท 0 Photos ยท 8 Likes
    Began 11 months ago by
    Recruit
    Latest Post 11 months ago by
    Vice Admiral
    Graham93
    Vice Admiral
    ๐Ÿ“ Vosper Crash Tender Motor
    46 Views ยท 3 Likes
    Online: 28 days ago
    Hi Roger,
    There are several Crash Tender builds on this site. Just search the BLOGS area for โ€˜Crash Tenderโ€™. Among these are at least two builds of the same VMV 46โ€ kit which should answer a lot of your questions, one by Robbob and one by Mturpin013
    Graham93
    johnf
    Warrant Officer
    54 Views ยท 2 Likes
    Online: 1 day ago
    Hi Roger,
    We have 3 times 34 inch Crash Tenders regularly sailing in the Leeds @ Bradford Club - two renovated vintage models and one from a modern SLEC kit.
    All use one single shaft with 35mm outrunner brushless motors and to put it mildly all go well over scale speed "on the plane".
    If using two shafts and motors ( as the two originals!) I would suggest using two times 28mm diameter brushless motors of around 30 mms long and 1000kv on your 3S Lipo batteries.
    Two speed controller s will of course then be needed - but just one large (and shared) Lipo should save valuable weight to get easily on to the plane. This especially applies if you fit a large and weighty water pump and pipework to squirt spectators!
    Good luck and hope this helps.
    John. ๐Ÿ˜€๐Ÿ˜€๐Ÿ˜€๐Ÿ˜€๐Ÿ˜€๐Ÿ˜€
    RogerC
    Recruit
    59 Views ยท 3 Likes
    Online: 10 days ago
    Got the Vosper Crash Tender kit from VMW for Xmas and thinking of building it with twin motors instead of the single shaft. Any thoughts or suggestions for brushless motors as hoping to use a couple of 5Ah 3S Lipos I currently have.
