Hi when you have built and sailed a couple of yachts, try looking at Sarik plans with laser cut wood part kits.
I have the Wild Duck laser cut wood and I found it nicely done and good quality wood and good value. I have yet to start my one but will report back when I do.
Fittings are available in general although I make nearly all mine. If you are OK with a soldering iron, bits of brass tube and hard brass wire then the yacht world is your oyster so to speak.
By the way a soft soldered joint is over 10 times stronger than an epoxy joint.
I use various diameters of brass tube for mast fittings and the old fashioned 'I' beam section brass curtain rail cut down for deck strong points.
I could go on if anyone is interested.
β©β©
No likes yet
for every like received
