2nd competition
2nd competition
https://www.modelboatmayhem.co.uk/forum/index.php?topic=68100.0
2nd competition
2nd competition
Have you tried firing it up at all? The worst things that can happen generally are running short of water, jammed safety valve or a gas explosion. I'm assuming the safety valve was checked as part of the boiler check and the fuel system (Propane/butane?) is easy enough to check ashore, so the main concern would be the water supply.
Does the boiler have an automatic feed pump? If not you need to check the water consumption and bring the boat back to the dock for a refill from time to time.
Is the boiler lagged, insulated, so that the burner doesn't ignite any fittings or melt the hull?
Personally I would give it a go and see how it works out - what are your main concerns?
2nd competition
2nd competition
it's aschame you can't run this beautifull model. A few of our members do have a similar boat.
is there anything we( i ) can do to help you out?
2nd competition
Oh also built the Truck and trailer with sound system that I can drive it to the water.
Liked by
Loading…
