    Spektrum DX6i compatible surface Rx advice pls...
    8 Posts ยท 5 Followers ยท 0 Photos ยท 23 Likes
    Began 11 months ago by
    Able Seaman
    Latest Post 11 months ago by
    Lieutenant
    United States
    Isaac
    Lieutenant
    ๐Ÿ‡บ๐Ÿ‡ธ United States
    ๐Ÿ“ Spektrum DX6i compatible surface Rx advice pls...
    33 Views ยท 2 Likes
    Online: 2 days ago
    I don't think the original post relates to submarines or carbon fiber boats.
    Isaac
    RodC
    Lieutenant
    ๐Ÿ‡จ๐Ÿ‡ฆ Canada
    34 Views ยท 4 Likes
    Country: ๐Ÿ‡จ๐Ÿ‡ฆ Canada
    Online: 16 hours ago
    900MHz & 2.4 GHz don't work well if the antenna is immersed, for example, video feed from submarine camera, or 2.4 used for control.
    And 2.4 in a carbonfibre glider fuselage is unreliable as the carbon fibre attentuates the rf signal intended for the receiver
    VA3ROD
    Isaac
    Lieutenant
    37 Views ยท 2 Likes
    Online: 2 days ago
    All 6 of my large boats use Spektrum radios. No issue. No need for an external antenna.
    PirateJohn
    Able Seaman
    28 Views ยท 3 Likes
    Online: 9 months ago
    Just clearing up a point. I have a dozen Spectrum and Orange receivers already. I was just concerned about 2.4Ghz and blocking due to water and in hull installation. Do you run additional aerial or are the Spektrum, Orange and Lemons just fine without this?
    Stuart Mackay
    Master Seaman
    40 Views ยท 3 Likes
    Online: 3 days ago
    Try Lemon and you wont go wrong !
    6 channel for only ยฃ15.99 here:
    https://www.ebay.co.uk/itm/134079968504
    Rookysailor
    Commodore
    41 Views ยท 4 Likes
    Online: 22 hours ago
    Hi John, I use Spektrum equipment, and the receivers I find best are, Spektrum AR6100e and for a cheaper one, from HobbyKing the Orange R615X works fine.
    Cheers Pete๐Ÿ˜Š
    Redpopman
    Chief Petty Officer 1st Class
    63 Views ยท 2 Likes
    Online: 23 hours ago
    have you tried phoning CMB (Cornwall Model Boats) I find them really helpful
    Red Budd
    PirateJohn
    Able Seaman
    58 Views ยท 3 Likes
    Hi,
    Returning to modelling and I have a DX6i Tx and am seeking advice on suitable/best compatible Rx for use on surface (marine) models?
    All input welcome (happy with clones as well as Spectrum kit)
    Thanks in advance.
