    Filling gaps in decks
    10 Posts ยท 6 Followers ยท 0 Photos ยท 40 Likes
    Began 10 months ago by
    Leading Seaman
    Latest Post 10 months ago by
    Rear Admiral
    United States
    LewZ
    Rear Admiral
    ๐Ÿ‡บ๐Ÿ‡ธ United States
    ๐Ÿ“ Filling gaps in decks
    22 Views ยท 4 Likes
    Online: 16 hours ago
    One other thing... there is some shrinkage with Tamiya's putty. Might be common with othe fillers as well, but Tamiya's shrinks about 20% (my guess). Best to overfill a bit or build up with several applications curing inbetween if it needs to be thick.
    Florida โ›ฑ๏ธ, USA ๐Ÿ˜
    Lew Zee (LewsModelBoats.org)
    RodC
    Lieutenant
    ๐Ÿ‡จ๐Ÿ‡ฆ Canada
    34 Views ยท 3 Likes
    Country: ๐Ÿ‡จ๐Ÿ‡ฆ Canada
    Online: 3 days ago
    I got a small bottle of acetone at Dollarama, that is our Dollar Store chain here in Southern Ontario. It is the traditional nail polish remover, it is also very good for getting varnish type Coatings off of copper wire so that it can be soldered๐Ÿ‘
    VA3ROD
    LewZ
    Rear Admiral
    25 Views ยท 5 Likes
    MEK is quite potent and a healt hazard. Safer choice is acetone which is safer (still be careful!). Acetone can be found in many store as nail polish remover (look for 100% acetone). Also low cost.
    Work very well with styrene and ABS. I 3D print with ABS and cement it to styrene.
    Acetone is very thin (much thinner than model cement) and can be applied various ways. I often use small brushes, tweezers, and even syringes.
    Florida โ›ฑ๏ธ , USA ๐Ÿ‡บ๐Ÿ‡ธ
    jumpugly
    Vice Admiral
    26 Views ยท 4 Likes
    Online: 2 hours ago
    I agree with Bobby. I grew up in the Squadron Green Putty. But, it is no longer available so the Tamiya white putty has taken over the market. Vallejo makes a plastic putty that is catching on in a big way. My son swears by it. It has a more liquid consistency and is easy to spread in tight spots. The war game folks love it.
    BobbyN
    Chief Petty Officer 2nd Class
    ๐Ÿ‡ฆ๐Ÿ‡บ Australia
    34 Views ยท 5 Likes
    Country: ๐Ÿ‡ฆ๐Ÿ‡บ Australia
    Online: 10 days ago
    I agree with Tamiya putty but there was a product which is now hard to get called Squadron putty, this product was very good as a plastic putty. There are a few other options which you could try out on some scrap. You could make your own putty by dissolving styrene in MEK I have used this to good effect especially with 3d printed parts. I use a runny version of this as my glue welds styrene very well. Also a friend uses baking soda with super glue. He swears by this.
    Hope this helps
    IanL1
    Warrant Officer
    ๐Ÿ‡ณ๐Ÿ‡ฟ New Zealand
    53 Views ยท 1 Like
    Country: ๐Ÿ‡ณ๐Ÿ‡ฟ New Zealand
    Online: 2 hours ago
    Sorry I can't help as I have never used this product. Cheers Ian
    Ian Langley
    jumpugly
    Vice Admiral
    56 Views ยท 4 Likes
    Online: 2 hours ago
    I am with Lew! Tamiya white putty is what I use!
    ๐Ÿ‘
    LewZ
    Rear Admiral
    57 Views ยท 5 Likes
    I find that Tamiya putty works very well sticking (more like fusing) to styrene as well to fingers. Sands very well. I have been using this for many years.
    Florida โ›ฑ๏ธ, USA ๐Ÿ‡บ๐Ÿ‡ธ
    RNinMunich
    Fleet Admiral
    ๐Ÿ‡ฉ๐Ÿ‡ช Germany
    73 Views ยท 4 Likes
    Country: ๐Ÿ‡ฉ๐Ÿ‡ช Germany
    Online: 23 seconds ago
    Hi Merchant 67,
    Balsa filler deffo no! You need something finer than that or P38 and above all something chemically designed to bond with the plastic.
    For styrene/polystyrene I use Plastic Putty.
    Here in Germany I use the Revell version, but there are many others.
    In UK for example from Deluxe Materials. See attached links.
    Cheers, Doug๐Ÿ˜Ž
    https://www.google.com/search?client=firefox-b-d&q=Revell+Plastic+Putty
    https://www.google.com/search?client=firefox-b-d&q=Plastic+Putty
    merchant67
    Leading Seaman
    64 Views ยท 5 Likes
    Online: 3 days ago
    I need to fill some gaps in styrene decks. Would it be better to use Model Lite balsa filler or ISOPON P38??
    Suggestions please!
