Domain Name Change...
Started by DodgyGeezer
4 replies 11 likes 0 followers Last activity: 3 months ago
#5 25
@cjanik001 I'm glad to hear that - that's exactly what the EeZeBilt ssries was originally designed to do. Infroduce beginners to the hobby cheaply so that they can go on to better things....
Right,
But I learned a lot with that build! Construction techniques, materials to use, and also hull design. This led me to investigate other boats to build including designing and constructing my own.
Thanks again
Liked by hermank and ChrisF
#3 29
@cjanik001 Ah - you were the one who found it very light, weren't you? There was a reason for this. the original Keil Kraft 'Otter' was almost a flat plate floating on top of the water, and looked most unrealistic. So I designed a very deep hull which is intended to take a heavy battery - 6 sub-C cells weighing about 12-14 oz. Then the boat is a reasonable weight, and doesn't bob about in the waves at all...
#2 29
Dodgy,
Thanks for your update. I got my start in model boating from your websites.
My first ever was the Beaver tug boat as well as a pair of Kestral’s for my Grandsons. Both are pictured in my harbor.
I will definitely revisit the new site addresses.
#1 36
A week or so ago, out of the blue, I got a message that my 'free' .tk website domains would now be chargeable. I haven't been able to get any information out of the .TK registrar, beyond the statement that my Domain Names will be closed at the end of this month unless I pay.
So I've finally had to bite the bullet and buy some new names from a more reputable source. At the end of this month, http://eezebilt.tk/, http://marinecraft.tk/, http://oldboats.tk/ and http://www.taycol.tk/ will presumably cease to function, and we will go onto the new names, which are:
http://eezebilt.uk/
http://marinecraft.uk/
http://oldboats.uk/
http://www.taycol.uk/
The new sites are available now, so if you hold these as links, now is a good time to change them. Ignore the banner warning I have put up - that's just a reminder, and will go away once the old site names die. Let me know if anything goes wrong. While you're at it, have a look at the new LARK Water Taxi EeZeBilt release...
