What do you do when...
How you deal with it depends on the size of your boating lake.
On small ones it is possible to have a vertical pole mounted on the bank with a long length of string attached to it. You then roll out the string and walk round until the string makes contact with your boat then slowly walk back bringing the boat to the side.
Building a rescue craft like you describe is perfectly normal as I have seen them from time to time and also you see them on You Tube when retrieving usually (you guess it), a fast electric in distress.
Good luck with your project and you can also disguise your "rescue boat" to look like a pusher tug etc.😁
if I get time today I'll dig out the winch I used for the trials on my destroyer, only operational boat at the time! Trouble with a destroyer - the stern is so low you can't reach the deck of most boats😲
I had also built a reversible ESC for the winch, a hefty commercial job with about a 385 motor I think. Ran on 6V.
Now I have the Southampton tug I was thinking of a much higher derrick, or A frame, on the stern!? Have some 0.5mm nylon line for the tow line, what do you think?
As an electronic engineer I sometimes need help with the mechanicals - which others seem to find sooooo easy 😲
Have right now a mechanical problem to solve on my Gina 2 fish cutter - more on that in the Blog. Cheers, Doug 😎
Getting my coat😊😊
Have rescued everything from a Micro Magic to a Marblehead.
Here's a pic of my tug bringing home an RG65, sticky rubber tyres on the side help. 😁
problem is the weight😲 The magnets are very light. I even tried casting a lump of lead on top of it. nix!
I came to the conclusion I needed something like a tin o' baked beans to weight the line 🤔
Still fiddlin'. Hope never dies😉
Re 'Flying boat: if my destroyer had gone into the powerful fountains it would have been propelled up to about 60 feet at least 😭
P.S.I don't get the "it's not a flying boat " bit though.Why would we imagine it was?😜😋🤔👍
This is my idea which fits on a number of boats.
Canabus
First time my destroyer conked out I swam out 'in me knickers' to rescue it cos the wind was pushing it towards the lake fountains. it's NOT a flying boat! Got a round of applause and some interesting suggestions from some of the er 'ladies' present 😲😉
Second time we had flat calm on a balmy summer evening and she started very slowly drifting home.
So as it was early evening we went to the lakeside restaurant terrace where I could enjoy a steak and a glass or two while keeping an eye on her progress. Hard life ain't it 😉
Whatever, I'm sure there's a more elegant solution than more plumbing than there is in my bathroom! I even once used my sharp pointed destroyer to push a failed plastic RTR so called speed boat home. Took a lot of manoeuvring with a long thin destroyer but we made it.
Once I managed to get it lined up and close enough to shore a good shove with all ahead flank then full astern let it run up the shore.
Was good helmsmanship practise.
A simple shaped rubber block I could hang over the bow would have made it much easier!
Cheers all, don't get stuck! Doug 😎
PS One other 'Schnapps idea' as they might call it here in Bavaria, I've been playing with for a while is a model of the 'Big Lifter'.
It's a conveyor ship like a big powered dry dock. To take on the load she floods huge tanks and sinks herself😲 slides under the load, pumps the water out again and up she comes load an' all! Would be fun wouldn't it?😉 All the bridge and accommodation superstructure and engine rooms are in the stern. At the bow there are only two tall towers for guidance when taking on the load. The rest is just flat loading deck. Sounds simple don' it 😁 an' a lot more fun than half the plumbing dept. of B&Q. 👍
PPS: I also tried the grab claw idea of Martin's. A sort of 4 prong grappling hook. As he rightly said the first snag is to get the line aboard the stricken vessel in the first place.
I tried it with one of the depth charge derricks on the stern of my destroyer. Reeling in - fine. Getting the line out ? Another kettle of fish. I considered a spring-loaded system to fire the line out IF I could make the winch free run to pay out!
Got no further than considering (the spring launcher I still have) before I completely stripped out the destroyer for a total refit.
Thinks, thinks, thinks ......
I guess the OP wants to assure himself he can rescue his own boat with something suitable when it's only him on the water. Fair enough. A tug is a nice idea IF you can get a tow line aboard the stricken vessel, so I suppose the all embracing lobster claw style has potential. A floating Brabham BT 34 comes to mind.
Ron
Or I've heard of plastic tubing being use as well!
Something like this!
73
Liked by
Loading…
