Display cases
Started by Ravydave52
2 replies 7 likes Last activity: 8 years ago
Display cases
Thank You Dave,
I will try this out as I too have not purchased any cases due to there high cost.👍
Regards Taffy.
Jonno
Display cases
Evenin' Dave,
Neat idea 👍 Must try that.
I have such a device and I too have been scratching 'me 'ead' about display cases.
Especially for my larger (4 to 5ft) ships with lotsa vulnerable twiddly bits which are too easy to break when dusting 😭 Cases that size usually have to be specially made and are simply unaffordable. Except for museums I suppose.
Cheers, Doug
Liked by figtree7nts and retirement-hobby
Display cases
Just been sourcing an array of display cabinet impossible cost ,can be more than the model.
So dug arround in my old data sheets from a few years ago and found laminating sheets !
Basically using A3 laminator run the sheet through once soft let cool and floppy run a second time it when cool is harder put through 3rd time when cool it’s harder and clearer almost like glass ? ( you MUST lay on flat surface each time or will distort)
Hope this helps Dave
Liked by Donnieboy and figtree7nts and
