Chris Craft Cobra by Dumas
Followers (1)
You have done an excellent job on her.
A true craftsmen.
Well done.
Found a few photos for your reference.
Might help.
What I did for my seats was to make a plug replicate of the seat that was 1/8" smaller so that I could cover the plug using a piece of white vinyl. I just like the plastic seats.
Nice job well done.
You have done a really fantastic job, well done.
A pleasure to see it thanks.
"Just finished the planking and currently fitting the fin to the deck. "
I trust that's a "dry fit" Jack.
I would prefer to varnish the deck first.
Saves a lot of masking if you use spray varnish, and makes sanding / flatting much easier without the fin in the way whether you spray or brush.
(If this is "egg sucking" - my apologies😔)
Link as you had posted it doesn't work😭
Inserted links work best if typed on a separate line
and without any additional characters.
It was the full stop at the end of your link address which stopped it working!
Now fixed.
BTW Very nice boat 👍👍👍
https://model-boats.com/harbour/19608
Used to run on a 540 but now it run an inrunner brushless on a 3 cell Lipo 👍.
Keep the updates coming.
Really taking shape now.
Well done.
I have been working on my 1955 Cobra since I retired in 2004. I'm at the point on glassing the hull. The bottom is glassed with 2 coats, but I had a problem with deck. I had to remove the fiber from the deck and start over and that's were I stand.
One thing that I did was cut the shaft hole for the drive line and did the same for rudder hole. This way I wouldn't mess up the fininshed glass work.
Would like to see more as you progress with the build.
I'd be inclined to replace those two planks where the top layer has frayed though.
Easier now than later, and you'll regret it later (it'll spoil the show) if you don't do it now😉
Very nice subject, only a few originals built in 1955 I believe.
BTW: How about transferring this project to the Build Blog section!?👍
Please don't make me replace those 2 planks, sir. Mahogany planking will hide my bad mistake. I caused this when trying to level the deck out when sanding got carried away. lol
Google Chris Craft Cobra RC model and this one of the first to come up-
https://www.rcgroups.com/forums/showthread.php?2229991-Chris-Craft-Cobra
Good luck🤞
Liked by
Loading…
