Current Website Support
85
Contributors
11
Subscribers
You are Not Registered
Donate for your silver medal ๐Ÿ…
ยฃ10
ยฃ15
ยฃ50
Subscribe for your gold medal ๐Ÿ…
ยฃ1
ยฃ3
ยฃ5
ยฃ10
    Followers
    Sea Commander.
    by Colin H ๐Ÿ‡ฌ๐Ÿ‡ง ( Captain)
    ๐Ÿ“ฃ
    Click To
    Follow
    17 Posts 16 Replies 10 Photos 29 Likes
    Nerys
    Captain
    ๐Ÿ“ Sea Commander.
    Online: 6 hours ago
    Sorry I did not notice your pm. Have answered it now.
    Nerys
    1
    Colin H
    Captain
    ๐Ÿ“ Sea Commander.
    Online: 6 seconds ago
    Thanks guys, but it looks like a new wiring job as some of the wiring has black wires instead of the nice shiny copper it should be, and I think it deserves a better motor, possibly a 600 as I have a few spare, and esc control. Also as it only needs 2 channels I will fit it with a new rx that will work with my tx's. But will stick to my vintage stock so could be 40mhz.
    So this one gets put aside till my old sea commander gets finished.
    But I will box up all the equipment ready to fit.
    Cheers Colin. ๐Ÿคž
    1
    Fair winds and calm waters, COLIN.
    RNinMunich
    Fleet Admiral
    ๐Ÿ“ Sea Commander.
    Country: ๐Ÿ‡ฉ๐Ÿ‡ช Germany
    Online: 16 seconds ago
    "The forward/reverse switch seems to be a similar system to the one I used in my Gato Submarine."
    Yep! A two microswitch version of JB's (?) servo operated DPST switch.๐Ÿ‘
    (Double Pole, Single Throw) or DPDoubleT if you want OFF in the middle.
    ๐Ÿ˜Ž
    2
    The Bugs are on the run ๐Ÿ˜Š โ„๏ธโ„๏ธโ„๏ธ Get out and run those Sea Trials!! ๐Ÿ˜‰ Cheers Doug
    RNinMunich
    Fleet Admiral
    ๐Ÿ“ Sea Commander.
    Exactamente Dodgy ๐Ÿ‘
    Martin is also correct.
    Point 2 was discussed a few days ago in a similar thread.
    The earth wire should be soldered or clamped to the prop tube of earth plate though.
    A loose connection like a croc clip can itself be a source of interference; so called "Metal to metal noise". That's also why I don't like all metal UJs for the prop shaft.
    Even 1:1 ships can suffer from problems with earthing plates!
    In the mid nineties I designed a COMMS system for a series of glass fibre minesweepers.
    Against my better judgement the yard decide to use vertical whip antennae for the HF radios.
    A vertical monopole whip antenna needs a good earth to act as it's counterpoise.
    "No problem " said the yard "We'll let a copper earth plate into the keel."
    After launching and a few weeks of fitting out and trials they complained that the HF comm efficiency and range was deteriorating. We tested all our radios, ATU and cabling and all was OK.
    Then we sent a diver down to inspect the earth plate.
    He came up and said "It looks like Chantilly lace!"
    Red faces at the yard and they coughed up for the Crossed Dipole antenna (with it's own built in counterpoise and ATU) which I wanted to fit in the first place ๐Ÿ˜‰
    Cheers, Doug ๐Ÿ˜Ž
    2
    DodgyGeezer
    Sub-Lieutenant
    ๐Ÿ“ Sea Commander.
    Online: 18 days ago
    1 - MacGregor radios had a non-industry-standard IF. So you may have problems sourcing a suitable pair of crystals.
    2 - Having a single Earth point was a standard interference suppression requirement. This used to be provided by connecting the negative side of the circuit to a plate in contact with the water, or, for convenience, the prop tube...
    3
    Colin H
    Captain
    ๐Ÿ“ Sea Commander.
    It's possible Martin. Or if wired in parallel for longer run time. Each battery pack is 6 volts. I'll have a look in the morning.
    1
    Martin555
    Admiral
    ๐Ÿ“ Sea Commander.
    Online: 3 hours ago
    The third battery might be for full speed ?
    I.e. Half speed/full speed system.
    1
    Colin H
    Captain
    ๐Ÿ“ Sea Commander.
    That's a good idea, I'll have to have a look. As there are 3 battery packs to connect, 1 to the motor switching system. 1 to the rx and not sure where the 3rd goes yet.
    1
    Martin555
    Admiral
    ๐Ÿ“ Sea Commander.
    Online: 3 hours ago
    Perhaps the crocodile clip connects directly to the battery , and all negative connections are taken from a central point.
    1
    Colin H
    Captain
    ๐Ÿ“ Sea Commander.
    Yes Martin, sounds right, but I've never seen it wired in this way with a crocodile clip. I usually have a capacitor in the circuit and hard wired.
    1
    Show 7 More Posts
