Oil for prop shafts
Started by Onemancave1
10 replies 26 likes Last activity: 6 years ago
Oil for prop shafts
I tend to use Lithium based grease. Works well and no pollution
Liked by Puddle-pirate and Martin555
Oil for prop shafts
Before using any type of oils, do a test on a bit of scap painted with what ever you used on the hull. Found out the hard way with the bottom of one of mine. White lithium grease seems to be the best.
Liked by Martin555 and Joe727
Oil for prop shafts
I just use white lithium grease as all my boats are slow movers or auxiliary motors in sailboats. The comments about drag are probably quite valid, if I ever build something quicker I will have to try the oil mix with grease!
Joe
Liked by Scratchbuilder and Martin555
Oil for prop shafts
Hi.
I use as shown in the pictures attached.
The oil in the bottle is my favourite which is just a little thicker than three in one Which I also use.
The silicone is also really good and for my use doesn’t really affect the drag factor.
Regards Bill.
Liked by Rookysailor and Joe727 and
Oil for prop shafts
I use multi purpose grease and mix in some 3 in 1 oil.
Then inject it in to the shafts using a syringe.
Liked by Joe727 and Onemancave1 and
Oil for prop shafts
Fitted shaft oilers and inject a squirt of light oil prior to each days use.
Found grease has too much drag
Liked by Joe727 and Martin555
