Hi Graham.
Plenty of things to try then...I'm sure you'll find the best solution.👍
I would wish that my 'ducks feet' suggestion works best and it's more in keeping too 😁🤣
Rob.
Thanks for the suggestion JB.
The hull does have a bow - its not very clear in the original photos. The top drawing shows the hull shape under the duck (in red). I'm going to try a couple of fins (shown in green) as these will be easy to add. The second drawing shows a view from the stern.
If that doesn't work, I'll look to extend the fins forward to produce a solution more like your suggestion.
Graham93
[{"id":"160312122176","name":"160312122176.jpg","caption":"","url":"https:\/\/model-boats.com\/media\/160312122176\/l","thumbUrl":"https:\/\/model-boats.com\/media\/160312122176\/s","isImage":true,"ext":"jpg"}]
Hi Graham, how about putting a bow on it ? as the round shape has no direction and would 'roll' around the centerline (especially with a jet unit which is very directional). You could incorporate Robs idea re the ducks feet for trailing fixed 'rudders'. It wouldn't have to be a sealed buoyant bow extension, just an open top and drain holes in the bottom perhaps.
[{"id":"160311190895","name":"160311190895.jpg","caption":"","url":"https:\/\/model-boats.com\/media\/160311190895\/l","thumbUrl":"https:\/\/model-boats.com\/media\/160311190895\/s","isImage":true,"ext":"jpg"}]
Hi Graham.
I think you've answered your own question with the keel solution.
I no hydrodynamicist 🤓 but I think the flow of water about a keel is to some extent responsible for the lateral stability as you called it just as a propellers wash about a rudder enable steering.
Try experimenting with a temporary keel of some sort, perhaps something in plastic 'gaffer taped' to the underside to see if that improves matters.
Perhaps adding some trailing 'ducks feet' as rudders would be worth trying too?
Rob
Hi Graham.
Rob
Hi Graham,
I think you hit the nail on the head when you said about fitting a keel.
I have seen a few models similar and they all had keels fitted.
I have a problem with my latest model (I hesitate to call it a boat!!) so I'm looking for advice on how to fix it.
PD Donald propulsion is provided by a water jet with steerable nozzle. The pictures are to give an idea of the hull shape. The problem is that it is very difficult to travel in a straight line. 🤔 Very easy to turn, and almost spin on the spot, but controlling it to sail straight is virtually impossible. I have reduced the throw on the steering nozzle, but it hasn't made much of a difference.
Any suggestions on how to fix this would be most welcome. My thoughts are I need to add something like a keel sticking down below the hull to give some lateral stability?
Graham93
(PD = Paddle Duck 🤣🤣)
[{"id":"160310584472","name":"160310584472.jpg","caption":"","url":"https:\/\/model-boats.com\/media\/160310584472\/l","thumbUrl":"https:\/\/model-boats.com\/media\/160310584472\/s","isImage":true,"ext":"jpg"},{"id":"160310584742","name":"160310584742.jpg","caption":"","url":"https:\/\/model-boats.com\/media\/160310584742\/l","thumbUrl":"https:\/\/model-boats.com\/media\/160310584742\/s","isImage":true,"ext":"jpg"}]
