Current Website Support
86
Contributors
27
Subscribers
You are Not Registered
Subscribe for your gold medal ๐Ÿ…
Until Cancelled
ยฃ1
ยฃ2
ยฃ3
ยฃ5
Donate for your silver medal ๐Ÿ…
12 Months
ยฃ10
ยฃ15
ยฃ50
    Login to Remove Ads
    Followers
    ABS plastic sheeting
    by Allan ๐Ÿ‡ฌ๐Ÿ‡ง ( Master Seaman)
    ๐Ÿ“ฃ
    Click To
    Follow
    15 Posts 14 Replies 0 Photos 10 Likes
    RNinMunich
    Fleet Admiral
    ๐Ÿ“ ABS plastic sheeting
    Country: ๐Ÿ‡ฉ๐Ÿ‡ช Germany
    Online: 42 minutes ago
    https://anticsonline.uk/Category/Plasticard-Sheet_N2162
    ๐Ÿ˜Ž
    ๐Ÿ”—
    2
    Griss
    Chief Petty Officer 2nd Class
    Online: 2 months ago
    Try Antics
    Rookysailor
    Commodore
    Online: 2 hours ago
    It really doesn't matter if the sheet is to big for you at the moment Allan, I'm sure you will find a use for it in the future, I keep a stock of sizes 10thou to 80thou
    and the good thing is, it doesn't eat much๐Ÿ˜
    Cheers, Pete
    Allan
    Master Seaman
    Online: 8 months ago
    Thank you very much, I did have a look on Amazon, but most had long delivery dates. I'll check out the Modellers shop , I located a sheet, but it was much larger than required. Many thanks.๐Ÿ‘
    2
    Rookysailor
    Commodore
    Online: 2 hours ago
    Hi Allan,
    Have you tried AMAZON, they have quite a few choices for plasticard sometimes referred to Hips.
    I presume that is what you are calling Abs SHEET,
    Also online is 'The New Modellers Shop' they seem to have quite a choice.
    All links below๐Ÿ‘
    Cheers, Pete๐Ÿ˜Š
    https://www.amazon.co.uk/WHITE-PLASTIC-PLASTICARD-0-75mm-SHE...
    https://www.newmodellersshop.co.uk/plasticard.htm
    https://www.amazon.co.uk/WHITE-PLASTIC-PLASTICARD-0-75mm-SHEETS/dp/B00F6S94SA/ref=sr_1_5?adgrpid=108047720767&gclid
    ๐Ÿ”—
    ๐Ÿ”—
    2
    Ron
    Rear Admiral
    Country: ๐Ÿ‡จ๐Ÿ‡ฆ Canada
    Online: 1 day ago
    Try your local department store signs used for advertising or other such.
    Maverick
    Online: 6 months ago
    You could try a company called Kit Form Services, although Howard sells Resin models he also has a section in the menu for Evergreen plastic extrusion and plastic sheet all of various sizes.
    Allan
    Master Seaman
    Thanks everyone, I'm on the case now, much appreciated to you all. ๐Ÿ‘๐Ÿ˜Š
    Allan
    Master Seaman
    Many thanks, much appreciated๐Ÿ‘
    Allan
    Master Seaman
    Hi Colin
    That is very helpful, much appreciated.
    Allan
    Show 5 More Posts
