Water cooling
Water cooling
Water cooling
It wouldn't be the first time. Perhaps a clue is in the name Maverick?
And don't try going to other forums with the same attitude, you may find them less patient and you will get short shift.
Water cooling
Please would you mind NOT using the language you have used in your post beginning with P. I am no prude and It is mild in the adult world,but my Grandchildren read and enjoy this site.I do not want them to be subjected to it if you don’t mind.
Regards Bill.
Water cooling
Water cooling
Second, I am not an expert, never have claimed to be, nor will I ever claim to be. i expressed my opinions based upon what I have learned in theis field, through experience and, even more so, from others who have taught me.
Third, You have posted questions on a forum, from which you received nuerous answers, some agree with what others have said, some do not. The lesson here is that there are so many ways to accomplish each goal, and it is up to you to gather information and then take the initiative to find your own answer. Tere are going to be answers that you don't like, so that you like and soem that you ignore. That is up to you, but is is YOUR build.None is going to builsd it for you. OH and by the way...you WILL screw up... so what? we all have and continue to. That is the learnig experience. I put my first build together with white glue. YUP.. the planks came off when I put it in the water, but I learned from it.
Fourth, this web site and others like it cntain ages of information that is at one's finger tips if one is willing to take the time to search and read. If you get totally stumped in research than reach out, but the answers to the questions you have posted so far are all answered in other posts. One of the great things I admire about the modelers in England and Europe is how they actually build models. Inn the US, everyone(almost except for die hards) wants instant gratification, ie, buy the model of the shelf and run it, boat, plane helicopter.when it breaks they throw it away because they do not know how it was built and can not fix it.
The initiative is yours. I am happy to help "newbies", but I have my own projects to work on as well.
Water cooling
I have not started to build yet as I'm learning, hopefully so I don't make rookie mistakes.
I do ask many questions on the same line, not because I don't agree or understand, but because I did not get the answer I posed.
I have my potential boat specifications as to size and propulsion system, yet the answers I get back relate to something else ie:-
1) told my motor was no use ...but no one has said why it's no use?
2)I asked about Li-po batteries and the different sizes. Or why some use NiHM .
Plus I find your comment KISS quite offensive, Just maybe you need to learn a little patience with guys new to the hobby, who obviously don't have your vast store of knowledge, and can only assume when you first starting building boats you knew it all!!!!
So extract the ensign from your rear end and be more relaxed and less stressed
Water cooling
Water cooling
Water cooling
l always try to keep the scoop within the circle of the prop l find that the prop wash keeps any weed or bits from entering the cooling pipework system.
Also at low speed the prop is still forcing water around the cooling system.
stay safe chaps. Jim.
Water cooling
Water cooling
Water cooling
Water cooling
Liked by
Loading…
