Use Tamiya white putty on RC boat abs/styrene hull
Started by beastlyfern
5 replies 15 likes Last activity: 4 years ago
Thanks everyone. Now to get down to work!
I've been using to Tamiya gray putty (I think it's the same chemical composition as white) for many years on my boats. I have not had any problems. This putty seems to adhere to just about everything, especially when my fingers.
The only thing I don't like about the Tamiya putty is that his it has a high shrinkage factor. So, when applying you need to use multiple layers with the final layer being a slight convex shape so it can be sanded down flush.
Liked by AndyN and ChrisG and
It can be ok on boats but still needs a coat of paint on it. I’ve used the putty you patch walls with. It’s the one that is pink and drys tan. It sands well but I coat with paint or even CA glue. It’s not waterproof but decent coating it can last. There is always the Bondo filler that is in a squeeze tube too.
Howard hager
Liked by AndyN and beastlyfern and
A good day
I always use 2 component epoxy
But a friend of mine is using the sprayable filler from MOTIP
Which you can buy in car shops
Herman lifeboat lover
Can I use Tamiya white putty to level out some small pits in a abs styrene hull on a rc boat model kit?
Is it going to be effected by the water? Of course I will be priming and painting/sealing over any areas.
I could use a two part epoxy putty but it is a pain to sand down for just some small imperfections.
Thanks
Liked by Colin H
