Battery connecting
Followers (5)
Battery connecting
Take care to connect the correct leads and you should have no problems. Good luck, and happy sailing !😉
Battery connecting
Battery connecting
Battery connecting
Battery connecting
Basically; connecting in series doubles the voltage at the same capacity.
Connecting in parallel doubles the capacity at the same voltage.
Thus to give a longer duration time you would need to connect your batteries in parallel, i.e. + to + and - to -. Two 5000mAh 7.4V batts would then give a total 10000mAh of 'nominal' capacity at 7.4V.
BUT: to do this safely both batteries MUST be the same type (make and preferably production batch) and the same state of charge.
Precautions must be taken to prevent a stronger battery from trying to charge the weaker one and maybe causing high back currents to flow which can cause a wiring fire and loss of the model.
This can be especially dangerous when using LiPo batteries.
The two batteries need to be connected via fast Schottky diodes to prevent this.
If you are not au fait with electronics and soldering I can recommend this simple solution;
a 'Parallel Power Board' from Action Electronics, sold by Component Shop, see link below.
Open the link and click on [PDF DATA SHEET] for a complete explanation.
https://www.componentshop.co.uk/p103-parallel-power-board.html.html
Liked by
Loading…
