Forward and Reverse control for TVR 1A Engine, and coupling solution.
Started by GaryLC
4 replies 26 likes Last activity: 3 years ago
These types of engines are always very fascinating.
Liked by GaryLC
I use a similar method on the African Queen, also use a pin coupling, the flywheel was drilled for two roll pins and a mechano wheel has corresponding slots for the pins to sit in...
Liked by GaryLC and AlessandroSPQR and
Thanks for the simple explanation 👍
Good to know 😊
Liked by AlessandroSPQR and GaryLC
Wonderful solution GLC. Elegant in simplicity👍👍👍👍👍
Rick
Liked by Doogle and Colin H and
Having several TVR 1A engines, the last one bought quite recently care of eBay, I found it quite difficult to set up the servo for the forward and reverse control, However, with a lot of trial and error would be solutions I finally cracked it, the solution is as per the photograph, which is to set up the servo, so as the servo arm screw is exactly the same height as the forward / reverse operating rod when level and dead center between forward and reverse, at the midway point, (neutral,) and the ferrule on the servo arm must be allowed to slide freely on the operating rod. This works extremely well and solves the problem.
The solution to the coupling problem is don't use one, fit a fly-wheel to the engine with two contact pins, and a tee bar onto the end of the prop-shaft. After all, you can't have a coupling problem if you don't have a coupling. Regards, Gary.
Liked by stevedownunder and Nickthesteam and
