Weight/ballast
Some examples:
Small balls have more density per cubic volume than larger balls because there is less voids between them. For this reason I use steel BB's. Just pour them in then pour some sealer. I use epoxy.
I made a small box (so the weight is removable) and filled it with hardened concrete nails. I had no need for them. Added some silicone sealant to prevent rattling then sealed the box.
Guidelines:
The best weight is the most dense (eco friendly) material at the lowest point in the hull. The object is to get the C.G. as low as possible. For fixed in ballast, the optimal would be to pour the material directly to the inner side of the bottom and harden or fill any loose ballast with something.
Use a little less fixed ballast than you need. This way you can "trim out" (level) the boat with removable adjustable (velcro?) ballast should you make any changes to the boat.
Hope this helps.
Florida ⛱️, USA 🇺🇸
