Engine Sound Effects
Check out my website www.forge-electronics.co.uk - if you have a gas turbine sound file to send me I can pop it into one of my FE101 units and post a video of the result. The sound is embedded in the program memory of the chip so cannot be altered by the user. I have one or two of these prototypes left for £25. You'd need to supply an amplifier for this version (unlike the FE100 - but no more of those left!)
I've done further work on using sounds stored on a microSD card so users can customise units themselves - however this is still work in progress and I've been busy this last year with gizmos for model aircraft, so it's on the back burner.
For lots of discrete sound EFFECTS see my 16 channel sound effect unit which has a built in 3W amplifier
Bluetooth speakers are cheap enough and come with amps built in
sounds can be recorded and used as a playlist on a smart phone
you can get a Bluetooth extender to increase range
this is all off the shelf tech and you probably have a smartphone already
I wanted a very specific sound unit for my Jaws boat Orca. Rather than just playing engine sounds etc, I wanted to be able to select specific tracks, music, dialogue etc from the film. I got all I needed from the internet, and saved on an sd card. Using a free download to convert music files, (google "lame for audacity")I then found an engine noise that I was able to have on a continuous loop behind the dialogue etc.
I then got a soundcard from technobots, and Alan devised a trigger unit, meaning I can select the tracks from a vacant channel on my transmitter sticks. eg, if I want the Jaws theme music, I have to move the stick 3 times up, if I want some dialogue from one of the characters, its 4 moves down, and so on, with something like 8 each direction, so 16 choices in all
I am not tech savvy, and I found it pretty easy to do. The system is now several years old, so things have moved on, Alan will no doubt be able to help
Paul
Steve.
http://www.technobotsonline.com/model-engine-sound-effects.html
Sure is a lot of money for sound effects, I have a Diesel engine sound affects in my tug serenity.
and when the tug is far out I can't here it! so is it really worth an investment of £165 is it!
That's practically half the value of another model. for that kind of purchase I hope it comes with Auto Pilot, LOL 😊
I would keep on searching the web, to see if you can find something more economical.
unless this is really what you want.
Ed
73
Drspock has suggested I try www.modelsoundsinc.com.
The company has sent me two sound bites, which are superb and they have recommended their ShockWave2-1x4x4 sound system kit.
At a cost of £118 plus £45 shipping this is not a cheap bit of kit.
It comes with a pre loaded micro SD.
To add more sounds, the purchase of software at a further cost of £26.75 is required, but it will only work with windows. I am a Mac user!
Whilst the equipment is no doubt of the best quality and certainly the sound bites are excellent, I am wondering if an outlay of £165 for one engine sound is worth it.
Anyone any thoughts?
Steve
Liked by
Loading…
