Li-Poly batteries
I think a lot of people (without the benefit of a long career in electronics) needed a 'Wake Up Call' on the dangers of and correct handling of LiPos. When possible try to find the manufacturers specs. in the net. I only buy from dealers who also post the specs. as PDF. No Spec. No Buy 🤔 The best manufacturers also print the max charge and discharge rates on the LiPo / LiFe etc pack itself. Rule of thumb: Max charge 2C, Max discharge; depends whether you want to run for ca 1sec or an hour or two 😉 Remember: 1000mAH (or 1AH) means the accu (strictly speaking LiPos etc are accumulators and not batteries 😉) can theoretically deliver 1Amp for 1 Hour IF hi quality and in perfect condition 'In this the most perfect of all possible worlds', or 2Amps for 1/2 hour and so on. But if you 'drain the tank' completely it will probably be ruined. Cheers Doug 😎
