Too Powerful Brushless ?
Now we can see the actual prop shaft and motor it is clear that the shaft is not supported inside the hull close to the coupling. At the high revs your motor achieves I am not surprised you have had problems.
I do agree with all the comments and help you have been offered and agree a 5mm shaft would help as well as a different motor.
I use 3 blade brass props with brushless and have no problems but do keep the prop size to a diameter no greater than the motor diameter, as Mark advises.
It's difficult to see how much space is in the hull to allow the motor coupling and shaft to be closer, but if you are replacing the shaft it may be a good time to reposition the motor and
the shaft with the prop attached to a slightly different angle. This will mean opening the slot and perhaps enlarging the outside skeg but you can easily repair any damage with plastic padding to make good.
Even if you keep the existing arrangement I suggest you provide support for the prop shaft close to the bearing as I suspect this is where you have experienced the problem with the vibration. A simple 2" block of wood attached to the keel and shaft would suffice.
Model looks very good and I look forward to seeing some on water shots.
