Thanks for the information, will read your blog
i think i found a method to line up the prop shaft with the motor. Getting the right angle.
Measures the motor shaft then prop shaft tube. Got the difference 1.550 in, then measurer the motor dia.
Took the difference and came up with .620, so I put a piece of .625in wood 6-inch-long, on the tube and put a ruler (scale) on top of that. Put the motor in line with the rule and it all linen up, so I got the angle right, and made adjustment to the motor mount, shimmed it till it was right. Then measure that and make a piece to fit. The motor helped with the magnets in side holding on to the ruler.
I have tried several way to get this angle and measuring didn’t work of me, or just a piece of tubing over the shaft,,, just not getting the right angle.
Maybe this will help someone in setting up there motors.
Now I’m going to finish up the placement of the batteries fuse, power disturbing boards, ESC and wire everything up and see if it WORK’S…
I did a lot of amp/watts/rpm and gps speed testing with my twin screw 4 foot fireboat, you might wnat to take a look. The quickest and easiest, and by far cheapest route is change from s prop to x prop thus increasing the pitch. They are real cheap to buy (plasic ones)so get a couple of sizes, start with the smallest. You can buy cheap inline amp meters, so using this you can see how the amp draw alters
Hi Sam,
Yes, by all means mount the motor on an angled block of wood to align the shafts correctly.
As you can see in my Sea Scout engine flat.
I used a standard 400 size motor mount (from Krick) screwed down to the block.
To align the shafts I used a chunk of brass rod drilled on my mini lathe to match both shaft diameters. Once you get the angle just right you can glue down the block, tack it first with cyano gel or 5 minute epoxy. When set you can remove the motor and mount fit the correct coupling. I try to avoid universal joints and use the flexible spiral types - again see the Sea Scout pic. You can also see that I took the opportunity during the refit to fit an oiler pipe as well 😉
Epoxy the block all round. When set reassemble motor and mounting bracket and check that the shaft rotates freely without straining / bending the coupling or binding anywhere.
Good luck. Cheers, Doug😎
[{"id":"156013591334","name":"156013591334.jpg","caption":"","url":"https:\/\/model-boats.com\/media\/156013591334\/l","thumbUrl":"https:\/\/model-boats.com\/media\/156013591334\/s","isImage":true,"ext":"jpg"},{"id":"1504000043","name":"1504000043.jpg","caption":"","url":"https:\/\/model-boats.com\/media\/1504000043\/l","thumbUrl":"https:\/\/model-boats.com\/media\/1504000043\/s","isImage":true,"ext":"jpg"},{"id":"156013604153","name":"156013604153.jpg","caption":"","url":"https:\/\/model-boats.com\/media\/156013604153\/l","thumbUrl":"https:\/\/model-boats.com\/media\/156013604153\/s","isImage":true,"ext":"jpg"}]
Hi Sam,
Ok i have to go back to school college to do the math in chapter 2.... but it looks like a 2 blade prop might be just as well as a 3 bladed one... just a question i wanted to ask to see if anyone got a big difference in speed or battery life...
I'm a scale speed guy also... just want to model to look like the real thing in the water... on 50 MPH that is why i got small eng. Now i hope they will be big enough to power the boat...
now on to mounting the motors..
any suggestion???? so far i have a plywood plate sitting on an angle on the bulk heads.
think i should put them on blocks of wood and match the angle of the shaft. or ????
thank you guys...
samc
thank you guys...
samc
Agreed Martin, one thing at a time!
BUT:
Stuart; I believe we are discussing your 24" Commander here.
In which case your results mirror mine with my 24" Sea Scout. Except that my prop shaft did not bind!!😉
It was also reluctant to plane with a 2S LiPo (7.4V nominal) but went very well and planed easily with a 3S (11.1V nominal). I also was using 4000mAH batteries.
I published my results using various batteries here in the Media - Video section.
Go to the Media Gallery and search for Sea Scout.
So, I would leave the motor and prop alone and (after fixing the prop shaft!!!) try a 3S battery.
I'm sure you will be satisfied 👍
Prop technology is complex as Martin said, our old friend Bernoulli raises his head for instance🤔 But, essentially bigger is better for more speed or same speed with lower shaft revolutions when applied to real size ships.
BUT 2: with our electric powered models bigger props often simply increase the load on the motor causing it to draw more current for a fractional increase in boat speed if any.
In essence props with fewer blades are inherently more efficient as you hinted. Minimum being 2 of course 🙄 Two bladers are popular with the Fast Electric guys for that reason.
I don't do speedboats, I'm a scale guy and my maxim is; If the real vessel had an XYZ screw then so will my model!
Summary; first fix the propshaft; lubrication, alignment with motor shaft, ensure a few thou of clearance between prop hub / locknut and the end of the shaft tube. Preferably with a thrust washer in between.
Second, fit a 3S battery preferably crosswise above the C of G of the boat. As you can see in the pic of my Sea Scout 'engine room' in your Commander thread.
For those with a mathematical mind, undying curiosity and an afternoon to spare I attach a paper on the Principles of Ship Propulsion from MAN, the supplier of small to huge diesels to probably a majority of ships (commercial and naval) built today.
You should find Chapter 2: Propeller Propulsion particularly illuminating! Happy reading 😉
Just remember the paper deals with real ships and real water, we have scale ships but not scale water🤔 Basic dynamics still apply though.
[{"id":"156008565650","name":"156008565650.pdf","caption":"","url":"https:\/\/model-boats.com\/media\/156008565650\/l","thumbUrl":"https:\/\/model-boats.com\/media\/156008565650\/s?preview=documents-3","isImage":false,"ext":"pdf"}]
BUT:
The only problem is that if you change several things at the same time you will not know what parts had the desired effect.
It may well be that changing motor and prop will be the answer.
Martin.
Martin.
Hi all,
Many thanks for all the fantastic responses and info.
I currently have a 7.4V S2 LiPo 4000mha, a 15A Motor and ESC with a 1000kva Motor. The prop I'm using is a 2 blade S type 35mm.
Apart from the Motor there is no weight up front in the bow, so can't reduce that much, but I am using a "heavy" servo at 68g in the stern, so will use a smaller less weighty servo.
I'll try changing the motor to 30A 1000Kva with a 42mm S type 2 blade to see what difference that makes. I also need to re-grease the prop shaft as suspect that it was running hot at the high rpm and caused a bit of speed loss.
I'll post a comparison video so you can see the results!
Hi,
If you have a left hand and a right hand propeller then you will need to reverse one of the motors.
As for propellers I think that at the and of the day you will have to experiment to find out what suits your needs as you must remember that you are dealing with scale models and that the water it is on is not at the same scale.
A 2-blade propeller produces two pressure pulses per revolution, whereas a 3-blade propeller will produce three smaller pulses per revolution for the same amount of total thrust. As a result, the 3-blade prop will be inherently smoother and therefore quieter.
A 4-blade propeller can improve all those characteristics that make for practical, all-around boat performance.
Four-blade props usually have a lower pitch to keep the rpms the same as a 3-blade.
But are 4-Blades Slow?
So, why might a 4-blade generally be slower than its 3-blade counterpart? To be honest, many 3-blade/4-blade speed comparisons are simply not fair. That’s because the respective propellers in question are simply different styles, designed with different purposes in mind—different diameters, rakes, cupping, and blade shapes.
If however, for comparison purposes, we take two propellers, identical in design (blade shape, diameter, rake, cup, etc.) that are appropriate for a given application, and simply add a propeller blade, we get a truer representation of just where the difference lies.
The addition of the extra blade causes increased drag, which, in turn, requires more horsepower, in order to achieve the same rpm. Since the horsepower is limited, the rpms drop, and the speed will tend to drop with it. This is why, when going from a 3-blade to a 4-blade, the pitch is dropped an inch, or more, in order to keep rpm parity. It is this difference in pitch that causes any potential speed differentials between the 3-blade and the 4.
I don't know if this will help you but this is a complex subject and you could get your self totally bogged down with all of the theory.
Martin.
Hi,
Hi doug and anyone out there....
you mentioned you tried 2 & 3 blade prop
what was your conclusion?? did the boat go faster or did it accelerated faster or is there advantage
2 blades are for speed,? and 3 are for power?
i have a dumas CC commander 36 inch long.
wondering if i should us 3 blade prop. comes with a 2 bladed and going to run twin motors. also should i revers one of the motors, for better control???
thank you samc
thank you samc
Samc
Agreed Martin👍
But don't forget that there was a reason why the company was called The Fairey Power Boat Company! They won race after race after race back then😉
There's always the 'throttle limiter' on the TX anyway! AKA Operator.
Doug 😎
Archimedes? EUREKA!! (Murmur from background "You don't smell so good either"!😁)
Agreed Martin👍
Doug 😎
Hi Doug,
I agree with you hole heartedly, as I said the complexity of this subject is a bit of an art form.
Bring back hand crank and Archimedes screw LOL!! (Mind you the operator used to burn out)
As you may have gathered I quite like scale models to move in a manner that they should do, I don't see the point of a nice scale model shooting across the water like a bullet unless it is a scale speed boat.
Martin.
Hi Doug,
Caution Martin!
A larger prop may only increase the current drawn by the motor without increasing speed.
in some cases less is more! Rule of thumb is prop diameter not significantly greater than the diameter of the motor.
I think the solution here may well lie in the type of prop and/or the battery.
Stuart hasn't revealed which battery he is using.
The motor and the boat are the same size as my Sea Scout which does pretty well with a 3 blade 35mm prop with pitch approx 1.4. Running off a 3S LiPo. Motor is a Propdrive 1kV ~30mm diameter.
In the past I tried a 35 and a 40mm two blade (S type) prop with sedate results compared with the 3 blade.
Shaft alignment and lubrication also plays an important role of course.
Cheer, Doug 😎
PS
"The pitch of the blades also determine the amount of distance per rotation that the boat will travel but that also has its limitations. This subject can get extremely complex."
You are so right Martin! The wood that you are putting a screw into stays put. Water doesn't🤔 So, amongst other things, you would have to know the 'Slip Ratio' of your prop design!!
Caution Martin!
Cheer, Doug 😎
PS
Hi,
Regarding motor speed/prop size.
There are so many factors to take in to consideration on this subject.
Also the fact that most model boats that you see go a lot faster than there proper scale speed.
After looking at your last video I would say that you have it about right, if you were to make it go faster firstly do you have the room to fit a larger propeller?
If not then the only course of action you have left is the motor size or blade pitch.
If you change the motor you could end up with the motor rotating so fast that the propeller will be next to useless.
(If you imagine a wood screw going in to wood the distance per rotation)
The pitch of the blades also determin the amount of distance per rotation that the boat will travel but that also has its limitations.
If your model is sitting at it's proper waterline then removing weight will not be the answer either.
Without getting technical I would personally try a different pitch first then assuming I had the room try a combination of prop size and pitch.
I don't know if this has helped.
Martin.
Hi,
My Mtroniks 1000KVA rated at 15A motor does not give my boat enough speed with a 35mm S type Prop. If I wanted to increase the speed, can I just increase the prop size or would I have to increase the motor size as well? What is the rule of thumb for increasing speed of the boat?
