This does work well Colin, I did the same thing on my Maiami and MTBs' Billings portholes about 12yrs ago, and used UHU glue poured in, with cling film on the back. Got a few small bubbles but you don't notice as the port holes are only around 5mm (no pun intended😁). As you say, allows the lights to show from the inside and keeps water out. For a very clear 'glass' you could use crystal clear Polyester encapsulating resin which is designed for jewelry, insects etc. Costs a bit more but very glass like. I did experiment with cabin sized windows using various resins and glues but got a lot of bubbles, and the std polyester resin was a bit opaque, (still made a nice solid window in 3mm balsa though. - about 40x30mm)
Hi Martin, yes I have tried it, but preferred to hard glaze as the silicone discoloured fairly quickly.
I'm always trying different things as like you I love to experiment to try things out and if they work it's great, but if it fails it doesn't matter as it then means I have learnt something.
Just a quick note, when using this method it is best done in the warm to allow the air bubbles to escape while still runy.
Or you get opaque windows.
The smaller one is 5.5mm opening and the larger one is 13mm opening.
They allow light through but are totally waterproof.
With practice it is possible to get a clear glazing.
All you have to remember is to use a plastic or film or even a silicone mat so that it is possible to lift off once set.
A £1.00 bond together set will do at least a hundred portholes up to 10mm diameter.
[{"id":"159128169361","name":"159128169361.jpg","caption":"","url":"https:\/\/model-boats.com\/media\/159128169361\/l","thumbUrl":"https:\/\/model-boats.com\/media\/159128169361\/s","isImage":true,"ext":"jpg"},{"id":"159128174394","name":"159128174394.jpg","caption":"","url":"https:\/\/model-boats.com\/media\/159128174394\/l","thumbUrl":"https:\/\/model-boats.com\/media\/159128174394\/s","isImage":true,"ext":"jpg"},{"id":"159128175061","name":"159128175061.jpg","caption":"","url":"https:\/\/model-boats.com\/media\/159128175061\/l","thumbUrl":"https:\/\/model-boats.com\/media\/159128175061\/s","isImage":true,"ext":"jpg"}]
