Test tank
Started by mturpin013
15 replies 25 likes Last activity: 5 years ago
Test tank
Logical Captain Kirk 😉
Fascinating! I shall look up the entomology of 'butt' (UK & US) in the Starfleet database.
Keep on barrelling along Tora.
I'm off to get my ears groomed now.
BTW; for the last 68 years it's been the Queen's English!😁
Liked by Rookysailor
Test tank
Doug,
...a rain barrel, what else would we call it? It is not exactly like we use the King's English... or for that matter know what it is! 😂😂😂😂
Liked by RNinMunich
Test tank
Hi Tora,
I realise that 'butt' has a totally different connotation (😮🙈) on your side of the pond!
So what do you guys call such a barrel for collecting rain water?
Spent some time in the States a while back; New york, Long Island, Buffalo, Boston, Philly, Chicago, Florida (just in time for Hurricane Andrew 🌪️🌩️🌧️) ...
But 'butts' (water or otherwise) weren't exactly the topic of conversation!! 🙉
Liked by ToraDog
Test tank
Thanks Nerys,
Perfectly! I have seen a few in use over hear, but they were not referred to as butts, but.......😀
Liked by RNinMunich
Test tank
Hi Tora,
A water Butt on this side of the pond is a receptacle for waste water, such as that draining off a roof. In days of yore, a wooden barrel was used, that's what my grandmother had, but these days a plastic creation, sort of oil drum shape, takes it's place. Hope that's clear.
Nerys
Liked by RNinMunich
Test tank
OK, my excuse is from being across the pond, but what is a water butt? Aside from that it looks perfect!
Test tank
Dimensions
Its a B&Q water butt which I had spare it holds 210 litres and measures 23" wide X 58" long 11" deep
The top is removable by the six eye bolts then the legs can fold and fit in the tank for storage, If I ever need to store it
Liked by Rookysailor and scout13 and
Test tank
Nicely made Mike.
Good use of cross halving joints on the frame 😀👍
All you need now is a loofah and a rubber duck 😆🦆
Liked by hmsnostalgia and RNinMunich and
Test tank
Excellent Mike, I've always got away with using the bath, but yours is a much better idea.
Nerys.
Liked by stevedownunder
Test tank
Now there are a couple of issues to be sorted in terms of battery size, prop size, motor size in a couple of my models I need a method of testing any changes I make in an easy way other than a 2 hour trip to my clubs lake.
So I thought I’d make a test tank, (easy just cut a water butt in half and stick back together end to end) I’ll not go into the detail but its enough to say that 3 weeks later I have a test tank and the pictures should show the construction method.
Liked by Hillro and RNinMunich and
