St Canute Rudder Control
Followers (1)
Your rear cabin looks like a Clyde Puffer? Is it a scratch build or a kit? Think those old puffers were dam good.
I agree l think will have to dig some of that block balsa out to make room, just hope l can get the linkage right to the rudder that’s something l find very difficult.
Thanks for all your time and help, much appreciated,
Richard
The main battery is fine and only connects to the Viper ESC which provides a reduced voltage to the RX and Servo. I use Mtronic and your selection is fine. I believe it should give a BEC of 5v but the specs only give the BEC current level so to be sure I would check the actual output with a meter. The model is small and providing your linkages are free running with no binding I doubt if you would have any problem. Yachts use their rudders far more often than your tug. I can see that space is at a premium but if all the space at the rear is available You may be able to fit a standard size servo, possibly mounted flat. Sorry without measurements its difficult to give more detail. If it was my model I think I would go with the small servo and keep an eye on it to see it was not overheating. If there is a problem it is not a dear item to replace and you have good access. Hope this helps. Dave
l might have a problem, the battery pack is a 6 cell 3700 7.2 v 3700mAh, have attached some photos below. I am using a Viper Marine 25 speed control and the receiver is a two channel Futaba R202GF. I only know the basics of RC, so that’s my stumbling block. Space in my model is very limited so l do need a relatively small rudder servo. Would you mind taking a look at my gear, do you think l have still have a burn out of l use this servo, would you know of any alternative to over come the voltage problem?
Many thanks for your kind help,
Richard
A quick look at the specs
Specifications
Motor Type: Coreless
Bearing Type: None
Speed Sec/60° (4.8V/6.0V): 0.20 / 0.17
Torque kg.cm (4.8V/6.0V): 1.2 / 1.5
Size in Millimetres: 22.61 x 11.43 x 23.88
Weight grams: 9.36.
Should be OK on a small slow model. Beware of exceeding 6v for the supply as the one in my RG65 yacht melted - I was using a ubec set at 6v at the time and should have used the 5v setting. The battery was a 6.6v LiFe. Dave
With very little space in my model of the St Canute ( Billing Boats) l am now looking for a small servo for the rudder control, l am thinking of the Hitec HS-5055MG basically as it’s the smallest l could find. Has anyone used this for a rudder control servo? as l am not sure if this ok to use. Have always had a problem setting up rudder control would anyone have any basic advice to help me set up the control as all my boats so far when in the null position it’s slightly to one side so the boat turns slightly. I know it’s a big ask but l sure could do with some help,
Many thanks
Richard
Liked by
Loading…
