Brushless motor problem
Followers (3)
If not you have to disconnect , I think the middle wire of the esc.
Someone will confirm if this is correct.
Thanks - could do with one myself
Eliminating the need for the rx and tx .
It seems brushed motors (except for RFI issues) are a lot simpler to set up. Thanks again, and I let you know what happens.
without a bit more info it's difficult to help with your problem 🤔
Above all; which ESC, brand & model number, and TX/RX are you using with your new brushless motor?
Liked by
Loading…
