Remote RX switching
Followers (4)
- stotty1111Gold
Remote RX switching
I was using a camera on each TX, so the video jumped from one to another,- this might fix that problem,- having just one TX and camera doing the work.
Biggest pain is that I just swapped the truck RX to suit another TX (forgot the boat and truck were on the same TX before I found this solution) so I'll have to change it all back (plus wiring up the relays) to try it out. I love wiring☹️ The jeep would be easier to do though, and it has a 'handbrake' for backing which the truck doesn't.
Remote RX switching
Good news on the remote front. All plain sailing from now on. On waters edge shots will be interesting to see.
I would use independent power supplies in such an installation as it will always be instantly available and avoid any problems any delay may cause.
Remote RX switching
The 2 RXs in the models are bound to the 9X TX. I haven't hooked up the second relay for the brushed ESC in the test, as it's not necessary to test the idea (does the same as the switch) I'll be taking the power for the relays from smaller batteries (only requires 5v) I could take power from the main battery, but would want to run a VR or UBEC (more wire😐) Relay can supposedly use from 5 to 30V, but I prefer to go with the minimum voltage which works, for safety.
Using a brushless plane ESC in the boat, and a Quicrun brushed car/boat ESC in the truck, I have to make sure that the throttle is right down when I turn the boat off, so when I swap models and turn the truck on, nothing happens till I move the throttle to the center, as it's FNR),- then it arms. Could turn the boat off, change models and put the stick to center, and it would arm straight away when turned on, but it's an added safety feature, giving you time to engage brain.😁
There would be a small drain on the batteries when the relay is operated in OFF mode (N/O) so an independent source is desirable, depending on how long one model is OFF, (better than a drain on the main battery) I could set the boat relay to N/O (uses on/on on/off button on remote) as a security in case the battery runs down, then the relay, if in the N/O for off, would close and start the boat. Better that than a cold swim.😁
Remote RX switching
Remote RX switching
Truck also runs 3 ESCs -- the 2 water drive ESCs (siamesed into the left centering elevator stick for throttle with centering rudder stick for water rudders) would not be armed for land use, but could also possibly be included in the set-up. Might not be an issue to leave them armed, as the jet only uses the rudder stick for starting/stopping the air/smoke/water system and it wouldn't matter if the rudders moved briefly, but they would both be turned off anyhow with the RX. All 3 should re-arm when the power comes back on (like a Quad).
Remote RX switching
Remote RX switching
The truck is amphibious as well, and the idea is to launch the boat, 'park' it, unhitch the trailer, drive the truck into the water, 'park' it and use it for a video camera 'stand', drive the boat round, and reverse the process.
With this relay I can just have the fobs clipped to the TX handle to turn off one or both models as required, just selecting the required model in the memory and switching it on. I'd set the NO/NC connection, so if the relay battery went flat, it would power up.
Remote RX switching
I had one for my birthday, still finding my way around it.
Remote RX switching
I just read your manual and I understand, now, whiel you are where you are. BTY, FrSky does allow binding to multiple different recievers. That aside, could you condense some of the channels you are using for your truck onto a multiswitcher or multiplexer, thereby freeing up enough channels for your boat?
TD
Remote RX switching
They both appear to be forcing purchase of their new expensive kit which is not backwards compatible. Why anyone would want to use the same binding on different models makes little sense and is in my opinion a retrograde step and removes the safety of previous systems.
I switched to a Radiomaster set earlier this year as it supports most types of kit and supports up to 16 channels.
Remote RX switching
As you are switching off your Tx to select a new model you can bind that to the Rx and it won't affect the original model. Switching back to the first model on the Tx should reconnect and you can switch off the second Rx. As I said before a Rx without a bound Tx can get confused and may not rebind correctly. Certainly worth a try to see if it works without any issues. I would also try on dry land at the lake when several other Tx's are switched on just to be sure
Remote RX switching
With a spare channel, this could be done with a custom electronic module on each model fitted between the Rx and the ESC and servos such that all Rx channels pass through the custom module. The spare channel would be used to 'tell' the custom module whether or not to allow the Rx to control the model. Both receivers would be bound to the same Tx channel. Quite tricky but feasible.
Alternatively, if you have deep pockets and long arms you may be able to afford a FlySky Paladin EV which has the ability to control two models simultaneously each with up to 18 channels:
https://www.flysky-cn.com/paladin-evdescription
Unfortunately, my arms aren't long enough to reach that far into my pockets 😂🤣
Graham93
Remote RX switching
Remote RX switching
Remote RX switching
Remote RX switching
The main problem is, if you turn a RX off with the TX (with the switch control coming from the RX as they do) you wouldn't be able to turn it back on.
Remote RX switching
On the site there are pdf files attached to each code, with an english version being listed
It worked fine on a quad model, one switch controlled a siren and the other a flashing amber light
Remote RX switching
What radio system are you using? Will your xmitter store more than one model? Can the model settings be changed?
I am speculating here, but it seems that you should be able to switch from model to model in the xmitter. Doing so should require that you assign different ID #'s to the different receivers in each model. This way you should be able to switch control from one model to another without controlling both at the same time.
It would help if you ID'd which system you are using.
Remote RX switching
Remote RX switching
Remote RX switching
Conrad sell a switch which might be suitable, I have one here somewhere, I'll try to find the leaflet!
Remote RX switching
I have used remotes to control lights on my models. Mine are infra red but I do believe they use some sort of code so they only respond to the one Tx.
If this is not the case could you not use two Rx both bound to the Tx and use channels 1&2 for the boat and 3&4 for the launch vehicle. As I assume it will be mostly for sailing you could use one switch to turn off the Launch vehicle.
I always like to hear of modellers pushing the boundaries and hope you find a solution
Remote RX switching
I was wanting to try this with my Hartley model and launching vehicle, so that either could be selected at the desired time,- eg,- select vehicle in TX, switch on RX remotely, carry out task (ie launching) switch off vehicle and select the boat in the TX and turn on with a second remote.
The only problem I can see with this idea, is if the clever Chinese have made all the remotes with the same frequency. I'll have to wait for the second switch to come to find out.
Works fine with the single ESC (test ESC has a BEC and no external on/off switch, so had to interrupt the POS wire through the switch) ESCs with external switches (such as the Quicrun type) would be simpler. Quick vid of it working.
Liked by
Loading…
