Prop Shaft lube
Followers (9)
- EdWBronze
- roycvBronze
- chugalone100Silver
- GregHiltzGold
Prop Shaft lube
Prop Shaft lube
Have settled on Automotive ATF; cheap, no viscous drag and readily available.
Must qualify this by advising all my models have oiler tubes and oil every time the boat is used.
Prop Shaft lube
Previously, I used oils and greases, including marine types, but found the petroleum jelly works great and not very messy.
Prop Shaft lube
regards
Prop Shaft lube
Formula,
One part each of WD40, vaseline, 3 in 1 oil.
Mix it up and suck it up into the tube via some clear tubing. I can tell you now it does not taste very nice.
regards
Prop Shaft lube
Prop Shaft lube
Prop Shaft lube
I use SAE 80-90 Gear Lube , 15 to 20 drops in the oil tube per year.
It is heavy enough to not drip from the tail.
Prop Shaft lube
Prop Shaft lube
Silverhook SGPGT60, White Grease... https://www.amazon.co.uk/dp/B00W6Q3B7A?ref=ppx_pop_mob_ap_share
Prop Shaft lube
I attach a picture of my preferred choice.
I pack the tube with the Flexishaft grease (available from most boating outlets)then top up with the oil in the bottle.
The oil in the bottle is years old and was what my Mum used on her sowing machine (I doubt you can it get now but it has the same consistency as 3 in 1.)
It does however depend on the type of craft you are sailing.The above is fine for my boats which are relatively slow scale speed.
If you going for the high speed racing boats I am sure there is different types of lubricants of which I have no knowledge personally.
Hope this helps.
Bill
Prop Shaft lube
Liked by
Loading…
