I do use Styrene often in my scratch builds, and I have also built three Krick cranes from printed sheet styrene. I tried being a 'purist' and using solvent glues, but my best results were in using good medium set(15 sec.) CA GLUE..
Like
โฉโฉ
Commodore-H
Len1
hermank
Andi1
Colin H
No likes yet
for every like received
Country: ๐ฌ๐ง United Kingdom
Online: 3 days ago
๐ View Profile
๐ฌ Send PM
๐ต Gift a Membership
When the hull and deck split on my fairwind due to rough parcel post handling although well packed and marked fragile. I used mek to tack back together and then used aeropoxy with light weight 24oz finishing cloth from inside the hull then used mek with a little bit of abs to thicken and weld all crackes and splits tog ether fnished with fine filler and spray seems all ok better than scrapping the hull, and boat hope this helps regards the yacht was a second hand buy regards peter l โตโตโต
Like
โฉโฉ
hermank
Colin H
Len1
jumpugly
No likes yet
I prepare my own glue using MEK with some ABS dissolved in it. It is a bit messy to prepare but it securely welds the two pieces of plastic together. I have used this for many years, prior to that I used Acribond 120 which gave good but was very thin and relied on the two parts fitting together very well. MEK with ABS dissolved makes the glue thicker and fills any small gaps.
Like
โฉโฉ
hermank
Colin H
Len1
jumpugly
PeterL3
RodC
No likes yet
Online: 4 months ago
๐ View Profile
๐ฌ Send PM
Stabilite express is what I use but I only find it on a German site, the example of the gluing instructions says acrylic glue? 'Use our recommended glue's' so is a product named in the list of also needed items to build at the front of the instruction booklet. The weld type joint is best, I use 'coffee stirring sticks from various Coffee shops to apply such glues as Stabilite 2 minutes the sticks have a great radius to provide a lovely corner filet the problem of aesthetics maybe an issue for viewable joints like above deck boom mounts as the Stabilite discolors.
Like
โฉโฉ
hermank
Colin H
Len1
PeterL3
jumpugly
No likes yet
Country: ๐บ๐ธ United States
Online: 10 days ago
๐ View Profile
๐ฌ Send PM
I have attached Kricks glueing instructions. Acrylic adhesive.Roughen all glueing with sand paper surfaces before appling adhisive do not apply thickglue beads but streak it on. I am doing everthing they said. HMMMM
Like
โฉโฉ
Len1
Colin H
jumpugly
Andi1
No likes yet
Online: 21 seconds ago
๐ View Profile
๐ฌ Send PM
For me I feel the strongest joint between two materials is a "weld" joint. That is where the materials actually dissolve into each other. For that I use standard styrene cements such as Plastruct, Testors, etc. Even acetone (100%, nail polish remover) works as it melts the surface of the styrene. As I occasionally cement ABS (3D printed) parts with styrene sheet and shapes, these work well. Don't use these if you are trying to cement other materials such as copper to styrene.
Lew Florida ๐ด, USA
Like
โฉโฉ
Len1
Colin H
PeterL3
Andi1
jumpugly
No likes yet
More Info
Main Menu
๐ค Model Boats
• Forum
• Build Blogs
• Media Gallery
• Boat Clubs & Lakes
• Events
• Boat Harbour
• How-To Articles
• Useful Links
This Website
๐ Search
๐ Guestbook
๐จโ๐ฉโ๐งโ๐ฆ Members (8,058)
๐ฃ Support
Hobby Supplies
๐๏ธ Online Shop
Login
๐ Login
๐ Create New Account
โผ
X
1 of 4
โบ
โ
Media Viewer
_
X
Share
X
Flag Inappropriate Post
X
Select Reason
