I have good results using BSI Medium Set CA glue, and since Balsam is very porous, I would use a quick shot (spray) of Accelerator (kicker), on the Balsa, then pur the CA glue on the GRP surface.
Like
โฉโฉ
No likes yet
for every like received
Country: ๐ฌ๐ง United Kingdom
Online: 3 days ago
๐ View Profile
๐ฌ Send PM
๐ต Gift a Membership
Iโm the same at the minute Peter thereโs a few things Iโve never done or tried as Iโm restoring a fairey huntsman 47 and had many a scratch head moment with many pars of my build but with the help of many guys on here Iโm getting there slowly and pleased with everyoneโs help I know everyoneโs got there own ways of doing build or with it being glue or paint youโll get the best help here , I have hope it goes well
Like
โฉโฉ
Len1
hermank
No likes yet
Online: 6 months ago
๐ View Profile
๐ฌ Send PM
Thank you everyone for your replies. First time I've worked with a grp hull (and very sketchy instructions). I'm starting a Mountfleet Models Brede which uses balsa to support the deck but will be filled around the deck to hull join with epoxy. I think I'll use the clear Gorilla glue for the supports. I've read Brede build instructions on another forum. Any other hints gratefully welcomed
Like
โฉโฉ
Len1
hermank
Wez
No likes yet
Country: ๐บ๐ธ United States
Online: 6 days ago
๐ View Profile
๐ฌ Send PM
Look at the question. It is about gluing "BALSA" wood to a GRP hull๐. I would say that using balsa is almost as bad as using expanded styrene foam. I have never done this nor do I plan to do so, especially for any joint requiring strength.
You need something that will seep deep into the wood. Possible let a full coat of super glue soak deep into the balsa (even the sides away from the joint) and let it dry, then apply another adhesive. Experiment first and let us know how it works.
Lew Florida๐ , USAโค๏ธ
Like
โฉโฉ
Len1
hermank
No likes yet
Online: 1 day ago
๐ View Profile
๐ฌ Send PM
Peter, If you want the best adhesive, and money isn't a problem, the get some Stablit Express, I think it's available from Cornwall Models but just google it, best glue I've ever used for GRP hulls.
Cheers, Pete๐
Like
โฉโฉ
Razor1955
Len1
roycv
No likes yet
Hi, I would use epoxy if you can as that is compatible with the GRP hull. You can get 90 seconds epoxy but the little I have used I have found the 5 minutes a better cure time. It allows a little more time for alignment etc. Cheers Ian๐
Like
โฉโฉ
Len1
Wez
jumpugly
No likes yet
Online: 14 hours ago
๐ View Profile
๐ฌ Send PM
Peter, Yours is one of those questions that is liable to get many, some contradictory, answers. There are lots of choices, as Wez pointed out Gorilla Glue will work. So will epoxy, as well as polyester resin that has been thickened.. some of the answer is what you are comfortable working with. I would stay away from Super Glue, no matter the type or brand.
Like
โฉโฉ
Len1
Wez
AlessandroSPQR
No likes yet
More Info
Main Menu
๐ค Model Boats
• Forum
• Build Blogs
• Media Gallery
• Boat Clubs & Lakes
• Events
• Boat Harbour
• How-To Articles
• Useful Links
• The Games Chest
This Website
๐ Search
๐ Guestbook
๐จโ๐ฉโ๐งโ๐ฆ Members (1,913)
๐ฃ Support
Hobby Supplies
๐๏ธ Online Shop
Login
๐ Login
๐ Create New Account
โผ
X
1 of 4
โบ
โ
Media Viewer
_
X
Share
X
Flag Inappropriate Post
X
Select Reason
