D class Dog Boat
Hi Shipmates,
There is a way to circumvent this problem for the impatient and curious😉
It is literally a 'work around' 🤔
Works in Windows, other Op Systems I don't know - look for equivalent commands.
First you have to LOGOUT. Yes really, trick won't work if you are logged in.
Then RIGHT CLICK on the pic (empty box) that you are curious about.
Select (Left click) OPEN IMAGE IN A NEW TAB (in Windows), other Op Systems, phones etc, may have other but similar commands.
You will then get the security message I posted below.
Left click ADVANCED. The window is extended with further info.
Scroll down and Left click ACCEPT RISK AND CONTINUE.
The picture will then open and if you go to any other page all pictures and Avatars etc will be visible. Incidentally, often MUCH larger than when you open them normally when logged in. Depends on the size (resolution) of the original pic.
Happy clicking / phone stabbing all 😉
