    "Airbrushing for Modelers 101"
    7 Posts ยท 5 Followers ยท 2 Photos ยท 14 Likes
    Began 5 months ago by
    Warrant Officer
    United States
    Latest Post 5 months ago by
    Sub-Lieutenant
    United States
    chugalone100
    Sub-Lieutenant
    ๐Ÿ‡บ๐Ÿ‡ธ United States
    ๐Ÿ“ "Airbrushing for Modelers 101"
    Online: 17 days ago
    Yes, for styrene I guess you should acrylics, la letโ€™s will damages styrene.
    bruce1946
    Warrant Officer
    39 Views ยท 1 Like
    Online: 19 days ago
    Chugalone I'm using Vallejo paints right now with a Iwata IPH 80 here is first time with this set up, Color is real bright due to the sun I'm buillding a Model Slipway boat the 'TRENT'
    I had to many issues paint with laquer and enamel paints due to the thinners on Styrene glues and fillers they seemed to made the Styrene and paint soft for several days. took to long to cure. befor applying 2nd coats.
    chugalone100
    Sub-Lieutenant
    47 Views ยท 5 Likes
    Online: 17 days ago
    Thanks Bruce, its always good to read as much information possible related to airbrushing if you want to create outstnading finishes in your models.
    I have being using airbrush before we had internet......๐Ÿ™„ and I learned the hard way...try and error until I got the hang of it.
    For me the main concern is to have a good paint/thinner ratio.
    Too much paint is what will cloge you tip and too much thinner will give you the runs.
    This is my favorite thinner, Tamiya X20-A.
    bruce1946
    Warrant Officer
    42 Views ยท 1 Like
    Online: 19 days ago
    Up date to missing link Do a search for " Airbrushing for modelers 101" hopeflly this works again
    Also if you're using the different plastic fillers Tamynia on your models don't use enamal or laquer paints the desolve these fillers.
    https://scale-model-workshop.com/lts49-005/005-3766/paint-scale-model/airbrush-s
    roycv
    Commodore
    54 Views ยท 1 Like
    Online: 38 minutes ago
    Hi Bruce the first link went 404 not found for me, second one worked!
    Roy๐Ÿ˜ฎ
    pressonreguardless
    Rear Admiral
    70 Views ยท 1 Like
    Online: 1 day ago
    Appreciate the Link, Mate
    I will be checking it out๐Ÿ‘๐Ÿ‘
    Trev
    bruce1946
    Warrant Officer
    69 Views ยท 5 Likes
    Online: 19 days ago
    I found this information very interesting.
    https://paulbudzik.com/tools-techniques/Airbrushing/airbrushing_for_modelers.htm
    https://scale-model-workshop.com/lts49-017/lts49-017-000.html
