Sprite
The new plywood skins that have just been delivered are far from being flat - they are very wavy.
If they had been sandwiched in the delivery box between the thicker sheets of plywood that I bought at the same time they may have been a little flatter?
As it was they were placed on the outside of the other sheets of wood with the hardwood strips that I ordered to use for stringers etc and held together with some elastic bands.
I think they will be OK once they are cut and then pinned and glued to the hull frames, but it is another example of the current crop of new wood not being anything like as good when delivered as it used to be just a few years ago.
The 4mm birch plywood is not very good either. When it is being cut, drilled, sanded or filed, the top laminate layers can chip-off giving some ragged edges.
Even the cabin front edges chipped off in places when being cut on the jig saw, and the Hegnar machine uses needle thin fine toothed blades that are not capable of cutting too fast.... or causing any other "user" inflicted damage to the plywood surface.
The wood quality is poor - the laminate layers are not bonded together very well at all and the edge "chips" are something that I have never experienced before in over 65 years of working with plywood!
Not impressed!
