Adhesives
Started by merchant67
8 replies 39 likes Last activity: 9 months ago
Adhesives
You might look into this product it might work for your needs https://www.amazon.com/Welding-Repair%EF%BC%8CCar-Automotive-Plastics%EF%BC%8CMetals%EF%BC%8CStainless-Steel%EF%BC%8CAluminum%EF%BC%8CIron%EF%BC%8C1-76/dp/B0CYGZ5GYF/ref=sxbs_sbv_search_btf?content-id=amzn1.sym.37132d36-da68-4ed0-8d23-842f0825e4d6%3Aamzn1.sym.37132d36-da68-4ed0-8d23-842f0825e4d6&crid=29HX8HGY0UGZ4&cv_ct_cx=3m%2Bscotch-weld%2Bdp420ns&keywords=3m%2Bscotch-weld%2Bdp420ns&pd_rd_i=B0CYGZ5GYF&pd_rd_r=e9075470-a50a-4de2-a892-3238ccd96e80&pd_rd_w=G3CIe&pd_rd_wg=U9X5I&pf_rd_p=37132d36-da68-4ed0-8d23-842f0825e4d6&pf_rd_r=DKFEBY70BCKMBASKXD1A&qid=1769126599&sbo=RZvfv%2F%2FHxDF%2BO5021pAnSA%3D%3D&sprefix=scotch%2BDP420n%2Caps%2C159&sr=1-1-a61ee601-6e56-4862-a8a2-1d3da5a5406f&th=1
Adhesives
Bruce, understood. But, I am hopelessly lost with soldering. I guess it would be best for Merchant to ditch the white metal stanchions and fabricate brass stanchion.
Adhesives
Jumpugly This is great for brass to brass but will not work for white metal Zinc. white metal temp is way lower temp than tinned solder.
Liked by hermank and RodC and
Adhesives
I wish these model kit manufactures would tell you the instructions on how to attach white metal parts to brass or quit putting it in their kits. epoxies and CA do not work any of the smallest shock (bump) to these joints will fail they will not last very long with transportation to and from home to pond. the zinc is oily and is a containment to solder and glues, so nothing sticks to it.
Normal solder temp for brass is too high for white metal.
Liked by RodC and Mike Stoney and
Adhesives
Hey M.-67!
Soft soldering works well with soldering grease and a medium soldering tip approx. 2-3 mm wide.
Brazing is not possible because white metal has a low melting point before the brazing alloy flows.
If possible, only use brass with brass. This is my experience, and I solder all railings with soft solder. It's easier to “rework”!
Where pressure builds up (steam engines), you should use hard soldering.
Okay?? Good luck!!
Greets Michel-C.
Liked by premecekcz and EdW and
Adhesives
What would be recommended to attach brass wire to a white metal stanchion???
The brass wire is the hand rail.
Many thanks in advance
Liked by hermank and Mike Stoney
