Current Website Support
87
Contributors
11
Subscribers
You are Not Registered
Donate for your silver medal ๐Ÿ…
ยฃ10
ยฃ15
ยฃ50
Subscribe for your gold medal ๐Ÿ…
ยฃ1
ยฃ3
ยฃ5
ยฃ10
    Followers
    Pretend deck planking
    by steve-d ๐Ÿ‡ฌ๐Ÿ‡ง ( Chief Petty Officer 2nd Class)
    ๐Ÿ“ฃ
    Click To
    Follow
    43 Posts 42 Replies 7 Photos 56 Likes
    TOWN3810
    Leading Seaman
    ๐Ÿ“ Pretend deck planking
    Online: 5 hours ago
    Hi again the thinnest popular ply is 2mm I use this for decks the raw edge i finish with half round 5x3 mm ramin beading or 3x2mm walnut half round from The Model Dockyard uk Sorry to keep on about the Biro and I know it probably wouldn't suit scale fans or the purist but it really does give a good effect especially on popular ply Cheers Ian
    TOWN3810
    Leading Seaman
    Online: 5 hours ago
    Hi I use popular ply for construction and decking it is much lighter than birch but is much stronger than light ply . The decking is a light straw colour and of very close uniform grain one coat of danish oil 'can be applied with a soft brush if you are worried about rags washed out with turps use dividers to measure plank widths use biro for curved planks use a wheeled block device as per the yacht books to follow deck edge apply several coats of oil burnish with fine Scotchbrite Cheers Ian
    1
    jacko
    Midshipman
    Online: 1 hour ago
    as for mc d coffee sticks i buy mine from Ebay 1000 at a time
    look for Wooden Coffee Tea Stirrers ๐Ÿ˜ ๐Ÿ‘๐Ÿ‘
    Zdenek
    Leading Seaman
    Country: ๐Ÿ‡จ๐Ÿ‡ฟ Czech Republic
    Online: 6 days ago
    The bend was done using a "jig" and two strips of a thin plywood as a protection of the planks (nor to distort them by clamps as it happened for the first time). First, I cooked them a little, of course. When dried, they kept the shape nicely.
    For caulking, the epoxy (or aliphatic wood glue) could be "injected" into the gaps left between the planks. I have tried all three methods (black paper, epoxy and aliphatic glue) and went for paper, at the end.
    3
    Zdenek
    Leading Seaman
    Online: 6 days ago
    As far as the bending of the planks is concerned: the thinner and wider the planks are, the more difficult the bending is if you don't want them twisted.
    As a "caulking", I usually use the black card (thickness of some 0,3 mm or so) and the result is not a tragedy, I would say (the planks on the picture are 4 x 2 mm, lime wood.
    You have to make a choice of planking method because everyone has his own "best" one ๐Ÿ˜‰.
    Good Luck!
    Zdenek
    3
    scout13
    Leading Seaman
    Online: 3 hours ago
    McDonald's have changed the shape of their stirrers all wavy sides
    I have seen a deck with the planks held down with drawing pins to make the gap between them. This was into a wooden sub structure then the gaps between the planks filed with black bumper body filler Scout
    1
    TOWN3810
    Leading Seaman
    Online: 5 hours ago
    EBAY FOR EVERYTHING IF THEY DONT HAVE IT IT DONT EXIST
    RNinMunich
    Fleet Admiral
    Country: ๐Ÿ‡ฉ๐Ÿ‡ช Germany
    Online: 4 hours ago
    Think I'd go for Maple Steve. Lime might be too light and bright.
    But you can always stain it reddish brown. Jotika or Billing Boats stain for example. I used Billing stains on my Sea Scout and was very happy with the result. A little of it goes a surprisingly long way ๐Ÿ˜‰ Doug
    Hmm! Just looked again at the stain bottles I used.
    Lo and behold - they have Jotika labels!!
    The Bugs are on the run ๐Ÿ˜Š โ„๏ธโ„๏ธโ„๏ธ Get out and run those Sea Trials!! ๐Ÿ˜‰ Cheers Doug
    steve-d
    Online: 5 months ago
    Found some info that said 16foot was the most common length. 22' is available but the price goes up considerably.
    16' will be fine by me as that is half the length of the actual boat so 16" planks on the model.
    Having trouble finding planks and sheet in the same wood and thickness. I need some sheet for the king planks etc.
    Have found Maple and Lime so now need to know which comes closest to Teak?
    Steve
    RNinMunich
    Fleet Admiral
    Online: 4 hours ago
    All right all right! I will I will! 'onest injun. No need to SHOUT ๐Ÿ˜‰
    At least I might if I knew where to get the stuff over here.
    Don't suppose it can be posted from the UK. ๐Ÿค”
    1
    Show 33 More Posts
