Hi Colin,
Ooh er! Goolies and ghosties and things that go bump in the night!😮
That's about €53 worth of RC Truck combo set you've been GIVEN there. Jammy so n so!👍
That motor (looks like an Inrunner!) should go pretty well on a 7.2V NiMh and would be exhilarating with a 10.8V NiMh!
I wouldn't recommend using a 12V NiMh or SLA with that 60A ESC though.
A fully charged 12V SLA can easily reach 13.6V or more, an NiMh perhaps 14V, and the motor could then draw 75A or more which the ESC will not put up with for very long!💥😭
It's rated for Less than 12V, Max 3S LiPo (11.1V nominal).
Prop size will affect the current draw so I don't think you should go above a 40mm job.
Any larger would probably just draw more current for no extra performance, maybe even less!
I might start with a 35mm and an 8.4V NiMh and see how it goes.
One of those little Current & Voltage meter jobs I posted recently would help you setting things up👍
I highly recommend getting the Programming Card to go with the ESC.
It's SOOO much easier to set them up than fiddling with the TX / RX and counting bleeps or flashes!! Links attached for the bits and the specs😉
Happy experimenting - WHEN you've actually built the boat!😁
Looking forward to the Blog and Trials👍
https://www.amazon.de/-/en/GoolRC-Motor-4300KV-Brushless-Offroad/dp/B07RZYHLB6
https://www.rcmoment.com/p-rm7712.html
https://www.ebay.de/itm/GoolRC-S3650-4300KV-Sensorless-Brushless-Motor-60A-Regler-Programm-Karte-R2K4/133542748229?hash=item1f17c4a045:g:rVYAAOSwI8VfgPTn
