Country: ๐ฌ๐ง United Kingdom
Online: 8 hours ago
๐ View Profile
๐ฌ Send PM
Hi RodC I agree it is unwise to connect batteries in Parallell for the reasons you state. You may well be able to use power diodes with SLA and NiMh batteries but this should not be used with LiPo's as their characteristics require close attention to each cells voltage. Overcharging or discharging any one cell can cause irreversible damage and in the worst case destruction of the cell and battery pack. LiPo's are available in very high capacitys and unless you are into high speed endurance racing I doubt if you would not be able to source a battery suitable for most sport usage. Used correctly LiPo's are safe for model use but I agree you should be aware of the issuses should you not follow the correct procedures when using or charging. dave976
Like
โฉโฉ
neilmc
Len1
pressonreguardless
No likes yet
for every like received
42yr experience here with rechargeable batteries. I wud definitely avoid parallelling any sort of rechargeable battery unless you use isolation power diodes to prevent the batteries trying to charge each other as the terminal voltages drop during the run. Personally I favour SLA (sealed lead acid) as their weight provides ballast. Yes you get tremendous energy density with LiPOs however I'm always feeling anxiety at the fire/explosion risk. I fully embraced NIMH back in the early 2000s for aircraft use & since weight is seldom an issue in semi-scale vessels I'm quite happy to keep my NIMH chargers out of landfill.
Like
โฉโฉ
neilmc
Len1
Colin H
No likes yet
Online: 8 days ago
๐ View Profile
๐ฌ Send PM
Hi,
I adapted both yours and Robs mount and it works an absolute treat ๐ On closer inspection youโve given me the solution as to how best mount the receiver ๐ If you have another photo at a different angle to show how itโs fixed in place that would be amazing, thereโs no point in reinventing a very professional wheel ๐๐
Cheers Neil
Like
โฉโฉ
Colin H
No likes yet
Learning so much more with each reply to my posts. One day I may have a boat in the water ๐ค
Online: 3 hours ago
๐ View Profile
๐ฌ Send PM
The housing you see is the same as mine (picture) which is home made as was Robs. All my brackets are made from 6mm black Perspex, it makes for a neat installation.
Like
โฉโฉ
Colin H
seafarer
stevedownunder
No likes yet
Online: 8 days ago
๐ View Profile
๐ฌ Send PM
Well it took a few weeks but happy with the end result and thanks to all for the advice. Just waiting on new coupling before mounting the motor then on to permanent fix of the superstructureโฆ.. really not looking forward to the fwd cabin as it seems everyone has issues with getting it right ๐
Like
โฉโฉ
Colin H
stevedownunder
Graham93
neilw
No likes yet
Online: 8 days ago
๐ View Profile
๐ฌ Send PM
So I think Iโve managed to construct a battery compartment that will suit and provide some flexibility for a future expansion. Just need some Velcro straps now to hold the battery in place. So thanks all on the advice
Also adapted RobBobs switch and fuse housing and I was pretty impressed with it at first. Instead of the XT60 connector being used to charge the battery in situ like Robs, I thought Iโd use it as just a connection for the battery. However I didnโt plan this very well and although the battery lead is long enough the pressure required to insert and remove the connector has the potential to break the bracket from its mounting. So as opposed to rebuilding Iโm thinking of just adding an extension. Iโm presuming the voltage drop across the additional connectors, fuse and switch wonโt be that detrimental to battery life? ๐ค
Like
โฉโฉ
Colin H
seafarer
stevedownunder
PeteJev
neilw
pressonreguardless
No likes yet
Cookies used in this website are gluten free, wheat free and dairy free. By using this website you agree to our use of cookies.
More Info
Main Menu
๐ค Model Boats
• Forum
• Build Blogs
• Media Gallery
• Boat Clubs & Lakes
• Events
• Boat Harbour
• How-To Articles
• Useful Links
This Website
๐ Search
๐ Guestbook
๐จโ๐ฉโ๐งโ๐ฆ Members (7,116)
๐ฃ Support
Hobby Supplies
๐๏ธ Online Shop
Login
๐ Login
๐ Create New Account
โผ
X
1 of 4
โบ
โ
Media Viewer
_
X
Share
X
Flag Inappropriate Post
X
Select Reason
