Today's wordle is waiting Wordle Today's clue: A long, narrow piece of wood Play now
#5250
Question of the Day?
Hi Ross, forgive my intrusion, but I wouldn't rely on model chains (regardless of scale) because, in my personal experience, they have very little tensile strength.
They're purely for aesthetics; I don't assign them any function.
This is easily explained because the links in model chains aren't welded but are joined only by bending.
But be careful, I repeat, I'm basing this only on my limited experience. I've always bought chains from Italian manufacturers that make them for static modeling and therefore only for aesthetic purposes.
However, it's easy to check: see if the links are welded together or not (of course, such a job would be more expensive for a manufacturer).
You can also test the tensile strength of your chain yourself by hanging increasing weights.
Liked by RossM
#5249
Hi Ross thanks for that I have put it in the trolley and at £1.24 I will add in my next order as P&P was £3!
Roy,
At ALI EXPRESS (chandler to the model ship world), Mine are 4mm links, but you can get anthing you want
Liked by roycv
#5247
Hi Ross, I think I will rely on the wire or cord with the chain a cosmetic attachment. Also I don't have any more of that chain! 😀
Hi Roy
Yes, I saw the line beside the chain. Do you think you have to upgrade to wire??🤔
#5245
Hi Ross if you look to the right of the chain there is a line but I think it should have been tighter as the intention was to thread the line through the chain, this was on a bowsie but may have loosened.
My model is to 1 : 35 scale. The hanging part of the chain is 5 inches long.
Hi Roy
That's REALLY close to the chain I have, that I'm planning on using. Now you have me Really nervous about it.
Is this one of those scaling problems where the wind is Increasing by the SCALE of the model? ie. on a 1/24th scale model, a 1 km wind will be 24 km wind, in scale? In your case your chain STRENGTH drops by a factor of the cube root of your SCALE
Ross
(hide a stainless steel fishing line down the centre of it for strength?? I tested the 0.2mm plastic coated 7 strand wire I have with 10 kg load)
#5243
Hey Pat
I don't have a CLUE when I'm on my Square rigger, but maybe I'😁m just being tacky
#5241
Hi Ross, picture of Broken chain. The links are about 3mm across. It was a lot stronger than a more scale like chain and this was all I had. Testing it for strength was not going to help.
Hi Pat it is no good you trying to baffle me with science! I am a thicko with a few nautical bits stuck on.😂😂
Liked by BOATSHED
#5238
Hi Roy, thanks for this information.
Over time, this forum (and partly the "question of the day") has inspired me to search for the exact English terms for nautical elements.
Since the usual translators were completely inadequate (imagine that the term "deck" for us is "ponte," but "ponte" in Italian also means bridge; another example: "mast" we translate as "albero," but "albero" also means "tree." Imagine if I wrote the tree on the bridge, it broke) and even the Italian-English nautical dictionaries weren't always helpful, I resorted to images and drawings.
If I see a drawing of the complete sail system with captions in English, everything is simpler and certainly unmistakable.
The problem is remembering it because there are so many specific nautical terms, but I'm slowly getting there.
It helps that I know the rigging and sails of boats and ships very well. There's certainly a big difference between a simple sloop and a full-rigged ship.
The English terminology that differentiates between "manovre fisse" standing rigging and "manovre correnti" running rigging was one of the first things I learned, along with sheets and shrouds, but thanks for reminding me anyway.
As the ancient Romans said: "repetita juvant."
Liked by SimpleSailor
#5237
On a square rigger both sheets and tacks control square sails sheet got from the clue of the sail aft where as tacks go from the windward lower corner of the sail forward hence the name tack.
Liked by RossM and AlessandroSPQR
#5235
Pook🐱☹️🤕
#5234
I have to ask. What are you using for chain, that it snaps?
Ross
Liked by AlessandroSPQR and hermank
#5233
Hi Aless... The fixed rigging is called the 'Standing' rigging and the rest is mostly 'Running' rigging. The ropes to control the angle of the sails are mainly called 'sheets' and these days have colour coding interwoven into the rope to help identify them.
Halyards are the ropes that haul up or put items in position. Could be flags or sails being hauled into position as in fore and aft sails.
Then there are clewlines buntlines and leechlines and footropes.
Ropes are measured in 'size' by their diameter so a 1 inch rope is about 0.3 inches thick.
It goes on......Any more contributions are welcome.
The bowsprit takes a lot of pressure and often has a chain from the tip going down to a low part of the bow. The forestay goes from the end of the bowsprit to the foremast.
On my sqaresail sailboat if the wind gets excessive the chain snaps, which it is at the moment awaiting repair!
From the description in the question, I understand (except for the last part, which is still a mystery) that they were referring to a fixed rigging we call a "strallo".
From my research, the closest thing to our term is the answer I gave.
Liked by SimpleSailor and hermank
#5231
My answer was a stab in the dark as what I know about sailing ships could be written on the back of a postage stamp, so I'll have to admit to luck on this occasion.
Dave in West Oxfordshire
Oh no another one wrong again. Was doing great at 100% now I dropped to 80%. Learning a lot and will have to keep with correct answers and wait a month or two. Anyway lots of fun😊👍😬
RonH
Liked by hermank and Steves-s and
#5229
BOWSPRIT GUYS are to the SIDES of the bowsprit to prevent the bowsprit side to side movement.
The BOBSTAY is the line that attaches from the bowsprit to the keel, to prevent the bowsprit from being pulled up and back from the force of the forestay
The BOBSTAY could be said to be preventing the foremast from shifting aft by supporting the forestay, but BOBSTAY wasn't a choice.
The answer given as correct FOREMAST STAYS would include FORE STAY, FORE TOPGALLANT STAY and BACK STAY. A bit misleading. . .
#5228
Understanding 19th-Century Ship Rigging
The correct answer is B. Backstays. In the context of 19th-century full-rigged ships, backstays were the component of the standing rigging primarily responsible for preventing the foremast from moving aft under the strain of the headsails and fore-topgallant staysail. Backstays are ropes or wires that run from the mast to the stern of the ship, counteracting the forward pull of the staysails and preventing the mast from being pushed backwards.
We talked about this sail for a long time, because I wanted to know its English name. Only Jumpugly answered correctly. Later, Pat confirmed this term with her very interesting questions and answers.
Then at least one AI question about this sail appeared in the "question of the day" section.
I realized that the naming of English sails depends greatly on their function and position.
Perhaps it would be helpful to answer today's question correctly to think about the other name you give to the Spanker sail.
#5225
Definitely remember this question not long ago, unfortunately I couldn’t remember the answer! Took a guess and got it right.
#5224
I have dropped a few lately but wright today😁 got a way to go to clear a red mark
Philuk👍
#5223
I think we have had this before but I couldn't remember the answer. Maybe I should have Googled it 😁
#5222
It's true, Steve, it was a unique story that also says a lot about human nature.
A highly metaphorical and symbolic painting was also made of it.
There are also paintings and engravings of the Mary Celeste, but there's no comparison.
Géricault's painting is still in every high school art book.
Liked by Steves-s
#5221
Ok, Alessandro about the Medusa raft. I had to do research on that...
150 people set adrift on a makeshift raft and after 13 days of cannibalism, murder and some weaker people being thrown overboard, they were then rescued. But only 15.😐😣.
This makes the Mary Celeste a mystery but a much less disaster.
Liked by AlessandroSPQR and RNinMunich
#5220
Same here, the question went right over my head, so I resorted to the longest answer. Turned out to be a good choice!
Liked by Bryan-the-pirate and Steves-s and
#5219
I'd like to say I understood the question and answer, but at I don't I used my universal which answer is the longest system.
Liked by Steves-s and roycv
#5215
Yes, Steve-S, the story of the Mary Celeste is the one that struck me the most when I first read it as a young man.
In some ways, it's also the one that impressed me the most and made me think only after the tragic story of the Meduse raft.
Liked by SimpleSailor and Steves-s
#5214
I agree Last In First Out. although now it is FIGF (first in gone forever). I find I start writing something and then all the words I expected to use go away and hide!
Liked by RNinMunich and Steves-s and
#5213
Roy,
"I am running out of brain area to take in new facts and I may have to forget something to make space!"
I know the feeling🙄
Curiously, rather than the FIFO system used by computer systems as we get older our brains start to work on a LIFO system🤔
Liked by SimpleSailor and Steves-s and
#5212
Hi Stephen,
Re the submarine question of 4th December-
Despite various complaints please do not change anything.
Answer C was correct, see my post to Roy.
The question simply needs to be read and interpreted correctly.
Admittedly some knowledge of Naval Operational Requirements and Operational Areas helps😉
#5211
Hi Doug fortunately I gave up smoking a long while ago!😊
The 'hundreds' was a quote from Wikipedia.
My initial doubts about Stirling powered subs was based on production stopped just over 10 years ago but after further digging was actually because of the payment conditions. Resolved a while later.
However, I accept that I was wrong, but happy the Stirling engine is used for subs. The Scotsman associated with its design may not be so happy to know that it is used as a weapon. Difficult to differentiate a method of keeping the peace from a means of active defence.
We have several model Stirling engines in our Model engineering club and many years ago we had a display for models which rotated around and driven by a hot air engine.
Many years ago one of our members designed a hot air engine entirely made from old storage discs and powered by a light bulb, it was displayed at a Model engineering exhibition maybe 25 years ago and because it was bright and shiny and moved it attracted much attention.
I am running out of brain area to take in new facts and I may have to forget something to make space!😁😁😁
Liked by Steves-s and RNinMunich
#5210
BTW Roy,
Re your post #5207 "Can't see the Americans abandoning Nuclear subs in favour of these."
You forget the Operational Requirement!
Sweden has no desire to play World Policeman like the USA.
Their main requirement is defence against the Russian Baltic Fleet not world cruises with a nuclear deterrent.
#5209
Hi Roy,
Scarcely hundreds!
I make it around 130, although it is highly questionable how many of the Russian subs are actually operational.🙄
Re Swedish subs-
Actually their diesel electric Gotland class (3 boats) has been happily operating Stirling Motors for nearly 30 years. The successor is already being built, 2 for Sweden and 3 for Poland, also using Stirling Motors from the Kockums yard.
Sure they are not going to win any speed competitions running on the Stirlings alone. But that's not the point.😉
When submerged the Gotlands can make 20 knots running the electric motors off batteries. Or tootle around at 5 to 6 knots on the Stirling motors driving a 75kW generator.
Alternately the Stirlings are used to recharge the batteries without the need to surface. Thus 'EXTENDING' the underwater endurance from a few days to a few weeks. And that is the key to this question!!
It asks about 'EXTENDED' operation NOT unlimited as per nuclear power.
Nuclear powered propulsion has never been designated AIP as it has never been dependent on air in the first place.
As for as acoustic stealth goes, the weak point of nuclear systems has always been the pumps in the essential cooling water circulation.
Sorry Roy but no cigar this time😉
https://en.wikipedia.org/wiki/Gotland-class_submarine
Liked by Steves-s
#5208
There are several hundred nuclear subs in the world, USA 66 and Russia 30 China 12. Of course if Russia does decide to attack Europe, non-political hot air may save us all yet!
The UK has survived over 2000 Russian incursions and attacks over the last year or so. The threat is there, if it happens they will run out of people to fight and money, as I doubt China will support them as their war is an Industrial one. They need American and European infra structure intact as countries that buy Chinese goods. Russia has only gas and oil and much of that is sanctioned.
It is an interesting scenario but rather dangerous. Oops sorry about the political side!
Liked by Steves-s
#5207
The heat source is diesel fuel and liquid oxygen. That seems neither one thing or the other. If they travel much distance from home port they could run out of LOX. They really only work in home waters.
Liked by Steves-s
#5206
I was one of them that chose the Sterling Engine because I thought there were to few nuclear subs and way more normal subs, plus it was a way too easy and obvious answer. However after I got it right. I was surprised, so I did some research and came across this.
https://www.saab.com/newsroom/stories/2015/march/the-secret-to-the-worlds-most-silent-submarine
Liked by Steves-s
#5205
Hi Fireboat yesterday's answer was'problematic', apparently their are 6 newly commissioned boats. They are for use in the seas around Europe, with 2 more expected around 2031.
I also picked the wrong answer with the submarine question along with 23 others 😂😂. Only 10 clever members got it correct..👍.
I was quite sure that we have had this question before and the answer was Nuclear??. 🤔🤔😕.
Today's 5th December question was one that took a full TV documentary to try to explain with no final conclusions. This I remembered from when I was very young 🎂🍦
, and it's a mystery that's stuck in my mind ever since 😊..
Liked by AlessandroSPQR and Bryan-the-pirate
#5203
Thank you guys - I answered D, and was very surprised to be told I was wrong. Nuclear is almost totally silent, except for some of the attachments, but any engine will have a sound profile that modern acoustics can pick up.
Liked by Steves-s and AndyN
#5202
I agree with Ron. And how in Heavens name (being polite) do you run a Stirling cycle engine in a submarine? What heat source?
Liked by RonH and Steves-s and
#5201 1
I chose answer D which is correct. Sorry but the answer to the question should be changed to D not C🤔😬😬
RonH
Liked by Steves-s and AndyN and
