Question of the Day?
Followers (74)
- chugalone100Silver
- NickthesteamSilver
- cumbraeSilver
- Stour-boyBronze
- EdWBronze
- zoomaBronze
- RNinMunichBronze
- Commodore-HGold
- Mike StoneyBronze
- WolleSilver
- TonyAshSilver
- jumpuglyGold
- SimpleSailorBronze
Showing the most recent 50 of 74 followers.
We carried on with a reach and the speed went up and up and the bow descended at least 12 inches. I asked how fast we were going, he said you won't want to know! When we got in he said about 25 knots well we had overtaken a speed boat who looked at us in shock as we sped by.
He got a lot of respect in the yacht club after that!
I have crewed on an Olympic class cat (Tornado) and the most comfortable position is on the trapeze. Got pictures somewhere of that.
Well you are complaining , so am I.
Two days running I have now come on here and it has said I had already answered the question.
I think something is not right here.
If they want to keep certain people on the top 100% then that's not right.
Not have the thing rigged to have it set to have it to auto answer for you without you coming on here.
Let me start with two preambles.
1. I'm not a sailing expert, and I have neither your knowledge nor your experience.
My theoretical and practical knowledge is minimal, but it's more than enough to answer questions like this.
What I know is limited to classic sails. Even though I've followed all the latest America's Cup races with great interest (the next ones will be held in Italy), the AC 75s and all the foiling sailboats still leave me speechless. It's incredible that a sailboat can go faster than the wind itself; to me, it's magic. I'm joking, of course.
2. When I read these types of questions, I'm sure I'm wrong because I never interpret sentences correctly. I only understood the last one I got wrong after reading the comments; I had completely misunderstood. After interpreting the question correctly, everything seemed simple.
Today, I think I interpreted correctly.
If I'm wrong, sailing experts will correct me. If I'm right, I hope this helps others better understand the topic.
SITUATIONS DESCRIBED IN THE QUESTION
Initial situation (image A)
I believe the initial situation was the one shown in figure A, where you can see (from above) a boat sailing at a close-reach (bolina larga) pace.
I drew the close-reach situation as a possible example, but it could also have been close-hauled.
I interpreted the upwind situation as a close-reach or close-hauled pace.
If you look at figure C, you can see that the boat wants to tack (going upwind) and sail from A to point D.
The initial situation is represented by the section between A and B where the boat receives the wind (see red arrows) at about 45 degrees or slightly less.
Changed Situation (Image B)
If the wind changes direction clockwise, I imagined the situation in Figure B.
Since, by convention, we indicate the wind's origin (where it comes from, not where it goes, unlike the current), I imagined the wind coming from a direction toward 90 degrees, therefore toward the point of sail called BEAM REACH.
From CLOSE REACH, it changes to BEAM REACH, for example, or something in between.
See the red arrows in Figure B.
If you look at Figure C, point B is the point where the wind changes. If the wind changes clockwise, the black arrows indicate the new wind direction.
Be careful! It could be a change from CLOSE HAULED to CLOSE REACH (still UPWIND, I believe) instead of from CLOSE REACH to BEAM REACH.
In that case, see the fourth and fifth images.
In both cases, the situation remains the same.
CONSEQUENCES ON THE BOAT AND DECISIONS TO BE MADE
A boat sailing upwind, if it experiences a wind shift like the one described, certainly benefits in speed.
When sailing upwind (Close Haul or Close Reach), you feel like you're traveling very fast because the sloping wind and the true wind combine, so the apparent wind is stronger.
In reality, sailing downwind allows for greater speed.
Broad Reach is the best, even if it doesn't seem like it, because the sloping wind subtracts from the true wind, so the apparent wind is less strong.
Similarly (to understand the concept), if I'm sailing close-hauled and want to increase speed, I can bear away a little (by bear away, I mean moving the bow away from the wind).
At this point, receiving a favor (a small gift) from the wind, I have no reason to change course.
In my opinion, I shouldn't luff, bear away, tack, or gybe.
Maybe I could gybe, but I wouldn't do it because if the initial course geometry was correct, it still is (even better), so why change it?
In any case, I would accommodate the wind change by loosening the sails a bit depending on the direction.
Jybing or bearing away would make sense, but it's probably not worthwhile, while luffing or tacking is pointless, unless the final destination has changed.
AI RESPONSE
I don't understand what this part means: "...your current tack becomes more lifted relative to the new wind direction..."
I don't understand the reasons behind ruling out the other hypotheses. I ruled them out for other reasons.
Maybe I didn't understand at all and was just lucky in that case.
Can one of you more experienced sailors draw a race course diagram (with boat direction, initial wind direction, changing wind direction, and possible strategies)?
Even when I read the correct answer I was not much the wiser to the "key principle in advanced racing strategy" 🙄🤕..
when i came on it said i had alrteady answered the question.
how can this happen.
it's not the first time this has happened to me.
and yes i am shouting very loud about it.
Very unlikely for us, hahaha.
No, that's fine; the forum should be a place for fun and learning, in my opinion.
However, I've seen scale ship models (static display models) covered in copper plates because they wanted to faithfully reproduce the original.
But I will not be covering it with copper sheeting.😊
I think that I should be quite safe as I only sail my boats in a landlocked lake 😐☺.
Do you think that I should be taking the forum much more seriously???🤔. I have learned a lot since joining when I asked if anyone could help with the use of the operation of "fighting lights" on my HDML.
In Italy, it's simply called "Teredine."
It's been well known since ancient times.
As Luckyduck rightly said, it was a major problem for wooden-hulled ships.
I love bivalve mollusks (especially because they're delicious to eat, like cephalopod mollusks), but Teredo Navalis have always disgusted and repelled me.
You're right, Steve, it's true, I had an advantage because the scientific name is closer to Italian than English.
However (being a fan of animals and taxonomy), I always identify animals by their scientific name.
It's represented by the binomial Linmeus (father of taxonomy).
The scientific name is valid and unique everywhere in the world. You can't go wrong if you use it.
If I see a blue shark (verdesca) I will say "Prionace Glauca" to make sure there are no misunderstandings.
Don't leave the Model Boats Forum. There are only about 2% of the 1,858 members doing the QOD on a regular basis, so it's not an important part of the Forum.
I think that although it would be easy to cheat, why bother? I went for Teredo but thought it was a worm apparently it is a clam! So learned something there.
I was in IT and came across some very clever and widely read people. As one guy described himself "A mine of useless information" I know some must take it as a challenge as from a previous post to 'fix it', when there was a' you have already answered the question' response.
Out of boredom and not ready for bed I was listening to some 'revenge / hard done by stories on you tube. They are put together by A.I. and so riddled with errors, assumptions, lack of continuity and stupid situations that maybe the future is bright for us humans after all.
I work on the assumption that between us we know everything! It's like if asked about our son and myself. I say I taught him everything he knows, but not everything I know.
Don't give up Pat! Just a bit of fun.
Re "It is statistically proven that ..."
BUT: There are lies, damn lies ... and statistics.
I never trust any statistic that I haven't falsified myself😁
Luckily I only had a fibre glass one.
I has a plaque on my Shetland 535 that said,
"If boat where meant to be built from fibreglass then GOD would have made trees from fibreglass".
I cannot BELIEVE that I have finally got up to 100%.
I will drop soon I know it.
With that in mind I have cancelled my subscription and will be closing my account at the end of the month
While I enjoyed the challenge of the question of the day - what is the point of the board ladder if all competitors do not follow the same rules, if you cheat it’s not about your nautical knowledge it about your ability to surf the net
Good luck to all those who continue
There I see giving multiple choice is not a fair way of accessing someone’s knowledge
With this in mind I have cancelled my subscription and will be closing my account at the end of the month
Good luck to all those that continue
😮 I should have gone for that but the only latin names I have come across have always had the same name twice as in Vulpes vulpes for fox and Meles meles for badger so I just went for the one with two names😆😆..
I couldn,t remember that question so it must have been before I got involved with this ☹️😭😭.
Besides which we had this once before, quite a while ago I think.
Liked by
Loading…
