Current Website Support
79
Contributors
8
Subscribers
You are Not Registered
Donate for your silver medal ๐Ÿ…
ยฃ10
ยฃ15
ยฃ50
Subscribe for your gold medal ๐Ÿ…
ยฃ1
ยฃ3
ยฃ5
ยฃ10
    Save £50 when you join Bulb
    Followers
    Modified Figures.
    by Martin555 ๐Ÿ‡ฌ๐Ÿ‡ง ( Rear Admiral)
    ๐Ÿ“ฃ
    Click To
    Follow
    51 Posts 50 Replies 21 Photos 74 Likes
    Martin555
    Rear Admiral
    ๐Ÿ“ Modified Figures.
    Online: 8 hours ago
    Hi Guys,
    I was thinking about doing the How To guide on this subject.
    And looking back through this thread most of it is pretty much covered.
    So i think the best thing to do is if you have any questions then i will do my best to answer them.
    1
    Martin555
    Rear Admiral
    Online: 8 hours ago
    Hi Peter,
    I am not that good.
    I just tinker and sometimes it works out ok.
    MouldBuilder
    Lieutenant
    Online: 2 days ago
    Hi Martin.
    A `how to` guide is a brilliant idea. Your skills have no boundaries.
    Ship builder.
    Doctor.
    Surgeon.
    Decorator.
    Electronics and computing wiz.
    Teacher.
    Have I missed anything?
    Looking forward to seeing the painted finished item.๐Ÿ˜Š
    1
    I promise I will finish a boat project before I start another......Maybe.
    Nerys
    Commander
    Online: 16 minutes ago
    I modified a couple of Mountfleet figures for my last barge and stuck arms back on with Araldite. Perhaps I was lucky. Bought two for my current project at Warwick today, hope they won't need modifying.
    Cheers, Nerys
    1
    Colin H
    Commander
    Online: 4 hours ago
    Hi Pete, thanks been there, but it seems that the type of plastic that doesn't seem to stick with any type of glue. Even solvent plastic weld.
    2
    Fair winds and calm waters, COLIN.
    Rookysailor
    Lieutenant
    Online: 20 hours ago
    Have you ever tried a hot melt glue gun Colin? you have to work quite quickly, as the glue goes off fast!
    but joints are sealed, and you can carve/sand off the excess.๐Ÿ˜
    Cheers, Pete
    2
    Colin H
    Commander
    Online: 4 hours ago
    Thanks Martin, ah plastic welding, why didn't I think of it, especially as when I have used hot wire it has melted the plastic.
    Just needed to be nudged in the right direction.
    1
    Martin555
    Rear Admiral
    Online: 8 hours ago
    Hi Colin,
    I have had the same problem in the past.
    The only way i got over it was to heat up a scalpel blade that was held in a small vice, then with a pieces of the plastic that had to be joined (one piece in each hand) quickly rub the pieces on the hot blade at the same time and then quickly stick them together.
    When set cut, fill, file, and sand until you have the required Finnish.
    2
    Colin H
    Commander
    Online: 4 hours ago
    Delicate cutting, but I find most of the small figures I have don't like being rejoined, I can't find a glue that works.
    And so I have been rejoining by inserting a hot wire into the limbs. But its hard to hide the joints.
    What's the secret oh master of the miniature limb manoeuvres.
    1
    Martin555
    Rear Admiral
    Online: 8 hours ago
    Hi Colin,
    This might help to explain what I have been trying to do.
    3
    Show 41 More Posts
