Today's wordle is waiting Wordle Today's clue: A long, narrow piece of wood Play now
#5100 1
Question of the Day?
This time I thought the answer was obvious.
In fact, it might be if you know the meaning of zenith well.
Liked by Steves-s
#5099 1
I am down to 83%, now if this were a proper exam that would get you a 'Distinction' So I am happy with that.
Liked by RNinMunich and Steves-s
#5098 1
So .... the QOD bug bit me, yet again.
I had been successfully avoiding getting "sucked in" for a while.
Then I made the mistake of "just looking" at a few questions.
I answered a couple of recent ones, some with knowledge, some with semi-educated guess, and some using the recently popular "longest answer" tactic.
Once bitten by the bug, I went back 30 days.
This got me 21 correct, 8 incorrect, and one where I had no idea so I googled it and didn't feel right answering after cheating.
I guess I'm back on the QOD train again for a while .....
Liked by RNinMunich and Steves-s and
#5093 1
Somewhat lucky guess today (11/15). It made the most sense to me ....
Liked by Steves-s and Nickthesteam and
#5092 1
Hi Doug is this all a dream? In my dreams I seem to come out all OK and less pains. It is you lot that may be the fiction!
I work on the premise that" I make model boats therefore I am!" I do go in and out of reality, well that's what my wife says.
Is my reality the same as yours the cunning part, if this all a fantasy that we share the same references, this kind of sophistication maybe beyond Stephen of the Fireboat's pay grade.
If it all were a fantasy I would like to pay for a s/w upgrade and lose the pain in my right knee and get back some of the attributes I had in the past. After all it would not be real money.
One other thing I think I have a bug in my s/w as my memory often fades a bit after lunch!
Liked by Newby7 and DWBrinkman
#5091 1
Hi Doug the answer B is correct. The comparison was with a long keel. The keel refered to acts as an aerofoil and does as it says.
Got model yachts with both keel forms and the long keel is not an aerofoil e.g. Inga IV she does her best but does not point up so well into wind. The sides of the keel are parallel so just represent wetted surface. I think it would give a smoother ride full size
The cheap plastic model yachts have the very deep keel and a pronounced profile of the keel with the weight at the bottom. Personally I dislike them but that is because I like my model yachts to look good out of the water. They sail well!
Full size in following seas which is decidedly dodgy needs sails to keep as stable as possible, a following wind can add excitement but added danger.
I have been in the above situation and it needs concentration to avoid rocking side to side. I expect I shall be sailing in March, April next year, will report if anything happens.
Liked by Steves-s and SimpleSailor
#5089 1
Hi All,
I think Stephen is doing a sterling job considering he does it out of love for the site. If more people subscribed it would help with the hosting costs and make his life easier.
Without pointing a finger I have noticed that some people post unnecessary club logos over and over again, multiple times on some posts, this is a waste of storage on the server.
Stephen must be a lot more tolerant than I am. In the past I have maintained and run large Intranet sites and users that post unnecessary content only got one warning then were locked out until their manager had pushed them to change their behaviour.
I doubt most members would appreciate how much time it takes to maintain a web site like this, let alone modifying anything on it.
My 2 pence worth
Ed 🤔
Ed
Liked by DuncanP and Steves-s and
#5088 1
Lots to unpack there Doug. I’ve always respected your thoughts on the site though.
Temu ads are concerning. You certainly shouldn’t be seeing any ads at all as a contributor. Separately I’ll see if Temu can be dropped as an advertiser anyway. I don’t control which ads come up, but I do think it’s possible to at least disable certain advertisers. Where abouts do you see these ads?
Server space/memory etc, the only real limitation I’m keeping my eye on at the moment is the 2GB database limit which is approaching, but it shouldn’t affect any of the improvements you’re suggesting on emojis, gifs and text formatting.
PC users can use any emoji already, but PC’s don’t typically have emoji keyboards like on smartphones. It’s that reason I put some limited emojis to pick from under the post text box. Can’t see the harm in changing the UI here and allowing for some kind of emoji picker instead with all emojis. I’ll see what I can do.
GIFs are more complex to do. So when images are uploaded, they’re all changed to a lower resolution PNG regardless of the original upload format. PNGs don’t animate. It’s boring though, I’ve wanted to post little animated GIFs before too.
It’s been a while since I’ve looked into it, but I’ll redo so. One consolation is that the original upload is saved, so it’s technically possible in retrospect to animate past uploaded GIFs.
Text formatting - this could be done through BB code. Not something I’ve ever enabled server side, but the use of [b]bold[/b], [u]underline[/u], [i]italic[/i] and [quote]quote[/quote] is doable. You won’t see the text effect until posted mind. I’ll add this to the Xmas list 😁
Finally on the question of the day - reason for tinkering was the 15 second wait time for the page to load. But yes, some code optimisations changed the scoring position numbers. I’ll fix that soon, should be an easy one.
Been quiet over the last few months, mostly due to a house move. Don’t recommend anyone to move house 🤣
Stephen
#5087 1
"A real mess. "
Yes Alessandro, I agree.
Seems that Stephen has been tinkering again and inadvertently caused a Right Royal Screw Up!
Sure he's corrected the 'Doppelgänge' appearances, and deleted the individual current position display, but the scoring is still screwed.
It now seems to calculate participant positions purely on the basis of how many participants are above him, rather than grouping together all those with the same score on one position as before.
Frankly this doesn't bother me unduly BUT ...
What does irritate me me is he is wasting time, and server space, on such tinkering but has done nothing about requests for other improvements to the user interface on the grounds that 'It would cost too much memory space on the server' or some such.
Requests made some years ago-
1. That PC users could use the same full range of emoticons that Smartphone App users can.
2. That PC users could use GIF emoticons.
(I have several with nautical connotations in my archive😂)
3. That full text formatting can be used, e.g. Italic, bold or underline.
All these requests were rejected on the grounds that it would require too much server memory space!
Question: How much has server memory capability increased and associated hardware and rental cost decreased in the intervening years?
(Yes guys I do contribute to these costs, for several years now. But I'm starting to reconsider when I see Temu ads appearing. A company which is currently under EU investigation for fraudulent marketing practices and substandard products.)
Question: What arrangement has Stephen entered into with Temu or is this yet another example of their intrusive marketing techniques that the EU is currently investigating?
Question: How much server space is now being used for functions that are now simply irritating us all? Or we don't really need?
Stephen: In all my decades of Electronic Service / Development and ultimately System Engineering one of the very first tenets I learned was -
IF IT AIN'T BROKE DON'T FIX IT!!
So why are you now tinkering with things on your site that have worked for years, and 'inadvertently' upsetting both the function and your members through such tinkering, rather than addressing the PC user interface improvements suggested over recent years?
Best regards, Doug.
PS As a former development Programmer I can appreciate that often changes to one section of a program can have unforeseen consequences somewhere else in the same App (as they call software these days🙄).
But that is what trials, simulations and debugging are for! Nicht wahr?
Liked by SimpleSailor
#5086 1
AI told me I got it wrong today (15.11.25) with answer C.
Told me B. was correct!
What a load of old cobblers awls!!😠
#5085 1
Roy,
Re: 'Perhaps all of you are unreal and just a functioning algorithm to keep me sane?'
"I think - therefore I am."😊 Hmm! Or do I just THINK I am?🤔
So where does that leave you Roy?😁
Do we just think that you are - and therefore YOU ARE? Or ...?
Or are we all just figments of some omnipresent programmer's imagination?
Commensurate with several scientist's conviction(🙄) that our entire universe and existence is nothing more than a hologram. 😂🤣😆
Liked by roycv
#5083 1
Lucky you Steve - overnight I have gone from 8th to 22nd!!!! Don't think we can blame AI for this - or has our data been hacked?
Liked by Steves-s
#5082 1
Yes I too had my name doubled 😎😎 but I was blaming my 12 year old phone 👎for the problem 😐. Sorry phone, and the position score has also changed to take into account how many 3rd, 4th, 5th.etc is before your actual position. I was shocked to find that I had suddenly gone from 5th to something like 16th 😩.That was before I had figured it out..
A.I. must be having a meltdown or laughing it's ??? Processor head off 😂😂😂..
Liked by AlessandroSPQR and RossM
#5081 1
PhilUK -
I had no idea of the answer (or even the question!) but I remembered someone saying the answer with the most words is usually the correct answer.
It wasn't!
Dave in West Oxfordshire
Liked by Steves-s
#5079 1
I think maybe it is A.I. diagnosing SS to have a split personality! We are looking at A.I. generated questions but is A.I. looking back and evaluating us?
#5078 1
Hi i would like to thank every one who have liked most post along the way, not sure if you are surposed to respond or just except it gracefully😂
Philuk
#5074 1
Rather shocked this morning to find I had dropped from 7th yesterday to 20th this morning! Having answered today's question correctly I went up to 18th !!???
Liked by Steves-s and AlessandroSPQR
#5069 1
Steve, I think the drama series set aboard a Grimsby Trawler was called "Snacker", featuring two young lads starting out as deckhands...
Liked by Steves-s
#5068 1
Something's wrong.
Nine days ago, a question I answered correctly was cancelled, and the rectangle went from green to gray.
Today, I was doubled.
Luckily, the second-best score isn't lower.
Liked by Steves-s
#5067 1
Hi, Phil I was going to put something like that about the trawler fishing programs on the TV, but I couldn't remember the name of the series.🤔
I always looked forward to watching it, not ever thinking it would help me in the future with this quiz.😀..
Today's SOLAS question has been on before in a slightly different manner so quite an easy one 😀😀.
Liked by Nickthesteam and Bryan-the-pirate
#5066 1
Me thinks i just accquired super powers😮
#5065 1
Most words seems to win every time!
Give a man a fish, and you feed him for a day. Teach a man to fish, and you get rid of him for the weekend.
Liked by Bryan-the-pirate
#5064 1
Hi i have a lot to thank deadly est catch program about trawler fishermen as they keep saying its up to captain where we fish.
Philuk👍
Liked by Steves-s and SouthportPat and
#5063 1
Todays was hard, each answer was reasonable so i went with the one with the most words.
Liked by SouthportPat and RubaDub and
#5062 1
The score has nothing to do with AI, it is simple mathematics. The total of correctly answered questions over the past 30 days divided by 30 and multiplied by 100 giving a percentage. Unfortunately not answering a question does not equal a correct answer. If it did I could have aced all the exams I have ever taken by not even attending 🤣
Ed
Liked by Steves-s and AlessandroSPQR and
#5061 1
Yes, I can see your point as well, but in theory, if not posting means no loss of points, there would be a temptation to hold on to a good position if you weren't sure about the answer.
I like to pit my wits against the daily question, and have to admit that at least half of my replies are a semi-educated guess. I know far more about model boats than I do about issues affecting full size boats. But i never check before submitting my guess!
#5060 1
Thanks for the advice, Pat, it's very valuable.
I see how you've changed your mind about people in top positions who consistently get 100% on their questionnaires.
Before, you doubted they could maintain that position for so long without consulting books or the internet before responding.
Now you believe it's possible.
#5059 1
I can see where you are coming from but because some can not answer in not fair as if penalised for getting it completely wrong
#5058 1
But if that was applied, then as soon as someone reaches 100% they could stop posting and just stay there.
BTW - congratulation on reaching the top, please don't take my comment personally!
#5057 1
That leads to another problem with the AI aloritham - I think if you dont answer you should stay where you are not be marked as wrong but thats only my opinion
#5056 1
The secret to getting to the top is to know the answer to the questions but the ones you get wrong will come around again sooner or later so remember them, if you know the answer it does not have to tax your brain if you have to remember something you dont its harder work
Soon due to dip again as I will be away without access to tinternet soon !!
Liked by SimpleSailor and AlessandroSPQR
#5055 1
Nov.11 2025 Remembrance Day and club meeting attended Legion ceremony Our club took some models for the attendees to view.After service at the Cenotaph.Legion lunch.In the evening Club meeting, where I picked up a model sports two seater that needs some TLC & should be ready for the 2026 season Snowstorm on the way home so took some time to get home and had a Rum & Coke a Cola AND forgot to do Question!!
#5054 1
Today's question has already been debated.
If I remember correctly, Ross and I explored a somewhat controversial option.
However, I believe there's no doubt about the correct answer today.
Liked by Steves-s and RossM
#5053 1
I agree with Phil.
Congrats, Pat.
Getting and maintaining a 100% correct answer rate without consulting books or the internet before answering is truly a remarkable achievement (especially considering the topics range from bulk cargo regulations to marine biology).
Liked by SimpleSailor and Nickthesteam
#5052 1
Hi Dave, this is truly a sad event.
For an Italian (but I think also for a European) it's unusual to talk about a storm on a lake. Ours are small bodies of water.
The great American lakes, in size, are comparable to seas like the Aegean, the Adriatic, and the Tyrrhenian.
Liked by DWBrinkman and Nickthesteam
#5051 1
I see southportpat has shot up throught the ranks now leading the class 😁 well done mate.
Philuk👍
